Old 05-31-2021, 12:40 PM
Richard Webb Richard Webb is offline
Default Ec250 balance shaft
Hi all
I need a little help with a 1997 ec 250 engine
I got it from a pal in a box in bits
The only concern i have is balance shaft parts
Does anyone have schematic of balance shaft as i need to know if it has thrust washers/spacers and position
Many thanks for any help
Old 05-31-2021, 02:11 PM
This maybe of some help.
socalspode has the pdf file.
http://www.gasgasrider.org/forum/showthread.php?t=3897
Old 06-09-2021, 08:26 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Here is a jpg of the crankshaft assembly and the CB shaft assembly of a 2003 Wild HP 300 Quad.
Next post will be the parts numbers and description for this photo.
File Type: jpg 2003 Wild HP300 Crank and CB Shaft parts diagram.jpg (81.6 KB, 28 views)
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-09-2021, 08:29 PM
Jim Cook's Avatar
Thumbs up
Here are the descriptions and part numbers for the above post's attached photo.
All the ME256 numbers are the same parts used in the '97-'98 250 engines.
Jim
File Type: jpg 2003 Wild HP300 Crank and CB Shaft Part numbers.jpg (100.9 KB, 27 views)
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 06-10-2021, 02:07 AM
Default Balance shaft info
Hi jim
You are a star
Thankyou
Old 06-10-2021, 09:55 AM
slocalspode's Avatar
Default CB engine
Take a close look at the attached picture.
Make sure the alignment dots on the two gears
match up.... Not like in the picture... This motor will
shake the crap out of the bike till you do.
I have a couple more pix if that might help.
Jeff
Old 06-10-2021, 11:15 PM
Jim Cook's Avatar
Thumbs up
Originally Posted by Richard Webb View Post
Hi jim
You are a star
Thankyou
You are very welcome.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
2015 Ec250 kickstart shaft In U.K Nicktamps "Wanted to Buy" & "Want To Trade" 2 12-02-2019 03:02 AM
2001 ec250 counter shaft seal Marc02ec250 Enduro Engine - 2 stroke 3 02-18-2018 09:17 PM
2001 gasgas ec250 help counter shaft and shifter seal Marc02ec250 Enduro Engine - 2 stroke 2 01-29-2018 06:07 PM
Ec250 Output Shaft seal Scotty97 Enduro Engine - 2 stroke 9 01-15-2016 07:59 PM
Balance shaft removal. darren Enduro Engine - 2 stroke 3 11-15-2009 05:18 PM
