Ec250 balance shaft
Hi all
I need a little help with a 1997 ec 250 engine I got it from a pal in a box in bits The only concern i have is balance shaft parts Does anyone have schematic of balance shaft as i need to know if it has thrust washers/spacers and position Many thanks for any help |
This maybe of some help.
socalspode has the pdf file. http://www.gasgasrider.org/forum/showthread.php?t=3897 |
Here is a jpg of the crankshaft assembly and the CB shaft assembly of a 2003 Wild HP 300 Quad.
Next post will be the parts numbers and description for this photo.
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
Here are the descriptions and part numbers for the above post's attached photo.
All the ME256 numbers are the same parts used in the '97-'98 250 engines. Jim
Balance shaft info
Hi jim
You are a star Thankyou |
CB engine
Take a close look at the attached picture.
Make sure the alignment dots on the two gears match up.... Not like in the picture... This motor will shake the crap out of the bike till you do. I have a couple more pix if that might help. Jeff |
2015 Ec250 kickstart shaft In U.K | Nicktamps | "Wanted to Buy" & "Want To Trade" | 2 | 12-02-2019 03:02 AM |
2001 ec250 counter shaft seal | Marc02ec250 | Enduro Engine - 2 stroke | 3 | 02-18-2018 09:17 PM |
2001 gasgas ec250 help counter shaft and shifter seal | Marc02ec250 | Enduro Engine - 2 stroke | 2 | 01-29-2018 06:07 PM |
Ec250 Output Shaft seal | Scotty97 | Enduro Engine - 2 stroke | 9 | 01-15-2016 07:59 PM |
Balance shaft removal. | darren | Enduro Engine - 2 stroke | 3 | 11-15-2009 05:18 PM |
