Old 05-06-2017, 06:38 PM
ismael ismael is offline
Default Speedometer reseting
Hi,
On my 2011 ec 300 all the functions on the speedometer are working but sometimes it shuts down and shows all the numbers. If I click the MODE button everything is fine except the hour goes to zero and all counters reset to zero. The total run time stays the same.
If I disconect the power supply, working only with the internal battery the same thing occurs.
Any thoughts?
Old 05-07-2017, 07:30 AM
Rampart Rampart is offline
Same? http://www.gasgasrider.org/forum/showthread.php?t=22645
Old 05-07-2017, 11:50 AM
Yes, it is. Sorry about the duplicate.
But I have already replaced the battery and the same thing happens.
Old 05-07-2017, 12:49 PM
I don't replace my yet, so as my friend, so i can
i can't tell about my issue.
Old 05-07-2017, 03:55 PM
I have replaced mine already. Please let me know how that works for you.
Old 05-09-2017, 04:39 PM
This is the response I got from Trail Tech support.
"I would recommend placing a small piece of foam in between the back of the battery and the battery cover. This will make sure the battery does not lose contact with the meter. What is happening is when you are riding it hard the battery is vibrating and then loses contact with the meter causing the reset. Using the foam will stop this."
Will let you know if this works when I get a chance.
Later.
Old 05-09-2017, 05:06 PM
Later.
I usually use a bit of electrical tape, folded over itself a few times. Foam may work better though.
Old 05-21-2017, 12:27 PM
So I put a little bit of foam between the battery and the baterry cover and it didn't work.
But I found this wich is probably the cause of it. Broken wire on the cable coming from the bike.
Old 05-21-2017, 12:29 PM
By the way, if anyone needs, the connector type is JWPF.
2014 prewired for speedometer? 95jersey General Discussions & Announcements 8 08-28-2015 03:23 PM
Speedometer problem ec 200 2004 adriano.ro Enduro Electrical & Wiring 2 07-24-2015 08:12 AM
tach/speedometer problems EC300 suomi Swedoo Enduro Electrical & Wiring 0 07-24-2015 01:37 AM
2011 xc 300 odo/speedometer ? Muddy General Discussions & Announcements 48 07-22-2013 10:38 AM
