Old 05-02-2017, 01:55 PM
Rampart Rampart is offline
Default What is wrong with my dashboard?
It goes from start, every time i kickstart
My friend have same gg with same problem
https://youtu.be/INyv1niDt_E
Old 05-02-2017, 06:42 PM
Replace the CR2032 battery in the back of it. It's clearly got no power when the engine is off. I've seen the same thing with 3 x trail techs on my bikes.
In other news, my speedo sensor has stopped working. Anyone know how to test?
Old 05-03-2017, 11:01 AM
Neil E. Neil E. is offline
Never had to check one, but I bet TrailTech can provide some info.
tech_support@trailtech.net
2011 EC250E
Old 05-03-2017, 12:02 PM
Thanks Neil. Will email them. They've been helpful in the past with other questions.
Old 05-03-2017, 02:13 PM
hamilton's Avatar
hamilton hamilton is offline
Easy check with ohm meter, magnet completes the circuit as it passes sensor.
Most times a broken wire at brake hose loop area from constant bending.
15 GASGAS EC 250
19 Sherco SE 125R
Old 05-03-2017, 03:38 PM
I'll replace the cable. I have some damage where it loops around the brake caliper from dragging in ruts/rocks. Can't see any exposed wires, but will most likely be the case.
I think I have a spare one floating around as well.
Old 05-11-2017, 04:02 PM
ismael ismael is offline
This is the response I got from Trail Tech support.
"I would recommend placing a small piece of foam in between the back of the battery and the battery cover. This will make sure the battery does not lose contact with the meter. What is happening is when you are riding it hard the battery is vibrating and then loses contact with the meter causing the reset. Using the foam will stop this."
Will let you know if this works when I get a chance.
Later.
What's wrong with my schematic? GGRider01 Enduro Electrical & Wiring 5 07-16-2016 07:17 PM
Trail Tech Stealth Striker and Dashboard wa_ndro Parts 4 08-19-2013 08:55 PM
WTF is wrong with my shock? n_green Enduro Suspension 9 02-09-2013 09:48 AM
Time is wrong Brian Suggestion Box 3 12-10-2009 03:33 PM
is it wrong to- mountain thumper General Discussions & Announcements 5 06-07-2008 10:10 PM
