Old 08-29-2021, 12:50 PM
Brad Brad is offline
Question Rear Wheel Bearings Spacer - sprocket side - EC300 (2006)
Part No. BE250318056 superceded by BE555012509
Which way should it be installed - A or B ? (see attachments)
File Type: jpg rear-wheel-bearings-spacer-fitment-c.jpg (13.0 KB, 20 views)
Old 08-29-2021, 07:13 PM
A
I also use the axle to keep the spacer aligned when installing the outer bearing.
Old 09-01-2021, 05:38 AM
Originally Posted by gasgasman View Post
A
I'm not convinced it is A for this spacer (BE555012509) which supercedes BE250318056. I've had a closer look and drawn it more to scale as per attachments. Seems to me like it B is the correct fitment?
Old 09-01-2021, 06:45 AM
cbutler's Avatar
cbutler cbutler is offline
http://www.gasgasrider.org/forum/showthread.php?t=2566
First post has pic of how it goes.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 09-01-2021, 06:57 AM
Originally Posted by cbutler View Post
That post refers to the old spacer BE250318056 which has been superceded by this new one BE555012509. They are very different.
Old 09-01-2021, 09:07 PM
cbutler's Avatar
They "look" different but the same purpose. It is the same put it in like gasgasman (the most knowledgeable person on this site) said or put it in like you want and do it again.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 09-02-2021, 04:58 AM
Have a close look at the spacer, it will have a step on it that ensures the torque of the axle nut only puts pressure on the bearing centre and not the seal/case area. A in the diagram above is correct.
Old 09-02-2021, 07:04 AM
http://www.gasgasrider.org/forum/member.php?u=2 gasgasman
http://www.gasgasrider.org/forum/member.php?u=1791 cbutler
Firstly to both you guys, sorry if you felt any disrespect was implied by me. It wasn't intended as I have huge respect for you and anyone who takes the time to contribute to this forum.
http://www.gasgasrider.org/forum/member.php?u=2703 Gasser Nate
I totally understand the "putting torque pressure on the wrong part of the bearing" thing which is why I asked the question.
I think I caused confusion because the drawings I put in the original post are not to scale, so sorry for that. I've now attached drawings of both A & B fitment which might help to resolve the question. To me B looks right, but would appreciate all your thoughts. Thanks.
Old 09-02-2021, 10:49 PM
This one is correct.
http://www.gasgasrider.org/forum/att...2&d=1630492679
Old 09-03-2021, 09:12 AM
Originally Posted by Gasser Nate View Post
Thanks Nate
Rear Wheel Spacer, Sprocket Side, Old Style Zman "Wanted to Buy" & "Want To Trade" 4 10-06-2016 06:13 AM
cross over for rear wheel dust seal/ wheel spacer jason tati Enduro Other... 3 07-16-2016 03:40 AM
Installing drive-side rear wheel bearings jdosher Enduro Chassis & Body 11 12-18-2014 12:08 PM
'06 EC300 Rear wheel bearings Eugene Enduro Chassis & Body 3 01-29-2009 08:18 AM
2006 Rear Wheel Bearings (fiche is wrong) cdn280 Enduro Chassis & Body 0 06-08-2007 05:03 AM
