Old 04-16-2008, 10:14 PM
MattR's Avatar
MattR MattR is offline
Default Rear Wheel Bearings - Installation Tip
This applies to the 2007/2008 bikes, but perhaps 2005+ (if anyone can confirm). Hopefully, this gives everyone a heads-up in order to prevent you from experiencing similar issues.
Background Info:
After installing new bearings, my rear wheel felt like it was binding when the nut was torqued to 60 ft-lbs. The aluminum stepped-washer between the 2 bearings on the sprocket side was replaced with the new bearings. Everything appeared to be lined up ok since the axle slid through easily during mounting.
Root Cause:
I really hated to push out my new bearings, but I needed to find the root cause. After reheating the hub, I tapped out my bearings and removed all spacers, etc..
First, I double-checked to make sure all bearings were correct. On the 2007/2008 bikes, the sprocket side has a large outer bearing (6005) and smaller inner bearing (6004). The brake side has the same smaller bearing (6004). Everything was good according to part numbers.
Next, I made an interesting observation on the aluminum stepped washer. If you hold it up to the light, you can slightly see one side stick out farther than the other. At first I thought it was just imagining something. Well, I held the washer in between the 6005 and 6004 bearings (like installed on the bike). The washer definitely has a slight asymmetric/offset to it. In the correct orientation, the washer OD has a slight clearance to both bearings (perhaps more clearance with the larger 6005 bearing). If you flip the washer over, then the washer OD contacts the larger 6005 bearing on both its OD and ID. This in effect causes the washer to drag on the bearing's OD (not good!). I could also see score/witness marks on the washer OD where it was scraping against the bearing OD.
Since I had my older parts handy, I compared those bearings and washer setup. I noticed the exact same thing (i.e., the asymmetric washer clearances). I could tell by the witness marks from the previous installation which bearing was contacting each washer side. For the record, my previous installation was correct and the washer had proper clearance with the larger 6005 bearing and wheel rotated freely.
Conclusion:
I believe the washer orientation is the root cause why I felt the binding in my rear wheel. I have reassembled my wheel with the washer in it's correct orientation (i.e., to ensure clearance with the larger bearing OD) and it now rotates properly when nut is torqued to 60 ft-lb.
Here is the incorrect installation:
Here is the correct installation:
Here is the stepped washer. Note: I marked the outboard side (with "O") to remind me during installation.
Matt
Current: 2009 Yamaha FZ1
Old 04-17-2008, 05:56 AM
cdn280 cdn280 is offline
Thanks for the info !
Old 08-23-2008, 09:36 PM
ok I have an identical binding issue on my 06 300. however I stumbled on this thread before I put my bearings back in. My washer is stepped on both sides btw. anyway I put it back just like in the correct installation pic. plus the washer seemed to want to go back that way anyway. I haven't pulled the wheel apart yet but .... can you think of any reason it would be binding even if the washer and bearings are in correctly?? I packed the area behind the seals with grease a-la the gmp method of water penetration prevention. Would too much grease be an issue?? one other point though I noticed that with the new bearings installed I could not spin the inner races by jambing my fingers in the axle hole. I think the last time I had bearings installed I could do that. I've been told that is not a big deal .. sometimes you can ... somtimes you can't ....
Old 08-23-2008, 09:37 PM
imo
This thread should be a sticky or put in the technical articles section!!
Old 08-24-2008, 09:07 AM
cladoo's Avatar
cladoo cladoo is offline
I am going o have to check mine as I find that my wheel binds somewhat after tightening also. This has been like this from the factory.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 03-10-2009, 07:01 PM
MattR's Avatar
Originally Posted by skid jackson View Post
My washer is stepped on both sides...
I should have clarified this previously. Sorry for the confusion...
Yes, the washer is stepped on both sides. The amount of step is different per side. Hence, the washer is slightly asymmetric. Just be careful with the orientation before installation. Check clearances before installing like my photo shows and everything will be good!
Matt
Old 03-11-2009, 01:37 AM
coolum74 coolum74 is offline
Tahnkyou Matt... Now it all starts to make sense.
Adam
2006 FSE450...Gone
2011 EC300e
Sunshine Coast, Queensland
Australia
Old 03-12-2009, 12:41 PM
NerdFrog NerdFrog is offline
I just replaced my rear wheel bearings last night. All cleaned up and greased profusely. Assembled and the wheel mounted.
Upon torquing the axle nut on the first time, successive "setting noises" were heard. Even before reaching specified torque of 98Nm, the rear wheel was binding.
I removed the sprocket side bearings carefully and noted that the inner seal of the 6005 bearing had crushed in and was binding the bearing.
I mounted a new bearing with the spacer "backwards" and remounted the wheel. Upon torquing, a few less "setting noises" were heard but the wheel still binds.
On my washer, there are protruding rings on both sides. I ended up installing the washer so that the inner races of both bearings contacted the protruding rings, avoiding any rings contacting the bearing seals.
The wheel still binds, but, oh well, I gotta ride tonight.
Ride to work: Pedal bike or 1986 Suzuki GS400S
Ride for fun: 2007 GasGas EC300
www.FVDRA.com
http://www.bluemountainmotorcycleclub.com
www.TeamCoastalCycling.com
Old 04-24-2010, 05:06 PM
GasGas's Avatar
GasGas GasGas is offline
I have had this problem ounce before. Then today I mounted up my spare u-rim and bam........Stuck wheel. Removed bearings and flipped washer. Still stuck. So I then mounted up the sprocket side
spacer, big outer bearing , washer and inner bearing with another spacer in the vice. Just snug everything spun nice. But when I tightened up the vise to simulate the torque of the rear axle guess
what.......................The washer had enough give in it to bend over and touch the outer race of the inner bearing. So I flipped the washer and tried it again. It did the same thing both ways. The cause is
the fact that the small surface of the spacer that fits inside the outer bearing is about a mm shy of touching the washer. ( I have 2 factory, 1 aftermarket and one i just made to try and they all have the
same length.) So this being the case the larger inner race on the outter bearing bends the washer around the smaller inner race of the inner bearing. I suspect that with repeated wheel changes the
washer just gets fatigued enough to give into the 60 lbs torque of the rear axle.
I will make a steel washer as a replacement. But for the hare scramble tomorrow, I just cut off the thin part of the washer. It now spins like butter!
Old 01-21-2012, 06:22 AM
400_racer 400_racer is offline
Hi All, first post
Having just bought an EC300 needing a few bits 'tinkering' with, this has been a really useful forum!
Ive tried searching but found nothing on this possible issue...
Im replacing the rear wheel bearings, old bearings came out ok and im now fitting the new ones. Have fitted the two on the sprocket side, with the washer in the middle in the correct orientation.
However, both bearings have locked up solid when in situ, is this normal? Doesnt seem right to me. I guess its where the washer contacts the inner race of both bearings or someting, but surely the washer and both inner races should turn together freely?
Thinking back, the old bearings were the same when in place, so maybe this is right and once all torqued up and pulled together they turn.
Have left the disc side bearing out for the time being incase the others need removing.
Any ideas? Thanks in advance for any advice!
Adrian
Rear wheel bearings on 03 kendunn Enduro Chassis & Body 8 01-06-2011 05:43 PM
Rear Wheel Bearings cladoo Enduro Chassis & Body 2 11-18-2008 10:14 AM
05 ec 300 rear wheel bearings burgo General Discussions & Announcements 1 06-08-2008 03:32 AM
rear wheel bearings smithys ec250 United Kingdom 3 04-23-2008 04:01 PM
Rear Wheel Bearings gasIdaho Enduro Chassis & Body 7 02-14-2008 08:34 AM
