Old 07-16-2010, 12:51 AM
iancp5's Avatar
iancp5 iancp5 is offline
I've just had some new spacers turn up that I had on back order. They are very different to the old. They are a little thicker, have a smaller OD - i.e would not fill the hub and have an odd chamfer on the outside that I can see no purpose for. Dealer swears these are what the factory are supplying now
Can anyone offer any advice?
Have they changed a lot?
Old 07-16-2010, 01:56 AM
noobi's Avatar
noobi noobi is offline
Do you mean like this http://www.gasgasrider.org/forum/showthread.php?t=2566 ?
I had the shop rebuild my rear wheel with the allballs kit, they must have thrown out the spacer, and just run the bearings, it probably lasted 200 odd km before the sprocket side spacer broke the center of the bearing and ceased onto the spacer. Made a rather strange noise after that....haha. I was lucky it lasted that long though, because it happened after a ride where there were sections that were tapped in 6th gear over sandy whoops, would not have been cool for them to fail then.
The shop replaced them at their cost, with the spacer no problems since.
Old 07-16-2010, 05:25 AM
iancp5's Avatar
Noobi,
No not like that. The ones in the link look like I was expecting. These things are weird.
By the way I don't think Allballs supply the spacer. Never been one when I've bought their kits.
Old 07-16-2010, 02:30 PM
noobi's Avatar
Originally Posted by iancp5 View Post
Noobi,
Oh ok, I wonder what the deal with that is, if you cant see a logical way that it fits they may have stuffed something up....
Thats correct, allballs do not supply the spacer so make sure to keep it!!!, and tell the shop that its there so they dont loose it. Not telling you ian, just a general warning
Old 07-18-2010, 01:30 AM
darren's Avatar
darren darren is offline
Matt
Circlip in the post to you.
Thrown out to all Does the talon hubs have this kind of set up?
All Balls ? Are they any good I bought a swinging arm kit and thought the quality was fairly pants.
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 07-18-2010, 07:39 AM
Skidad's Avatar
Skidad Skidad is offline
From what I have read the Talon hubs also have a dual bearing setup on the drive side. I have no idea if it's 2 seperate bearings like the GG or a dual row bearing which to me makes more sense.
97 KTM 250 EXC (sold)
2016 Trek Remedy 29er
Old 07-24-2010, 07:05 AM
vfrrocks's Avatar
vfrrocks vfrrocks is offline
Question anybody have the measurements?
so back to the original question: (dimensions of the spacer)
i would like to also know what the dimensions are, but at least the thickness(distance between the bearings). mine is worn and i would like to make a new one from stainless.
thanks
ken
you don't have to live on the edge, just know where it is.
____________________
Ken
05 GasGas EC300
05 Honda CRF450X
98 Honda VFR800
89 Honda RC31
Old 07-24-2010, 10:13 AM
PEB PEB is offline
I have a new on e on the way. I ll get some measurements from the new one before I install it. Can you make a small run of them?
Rear Wheel Bearing 2001 XC250 thomasbyrd Enduro Chassis & Body 0 10-04-2009 02:04 PM
Front Wheel Bearing Removal coolum74 General Discussions & Announcements 13 02-24-2009 03:29 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
05 250 front wheel bearing seal #??? Bandit9 Enduro Chassis & Body 3 10-29-2007 06:49 PM
Rear wheel bearing ? ktmguy23 Enduro Chassis & Body 1 03-22-2007 06:45 AM
