Old 01-20-2023, 09:45 PM
edodd19 edodd19 is offline
Default Floating the ground, 13 EC300
I recently purchased a 2013 EC300. I want to convert it to DC power. From my research I need to float the ground. Does anyone have the exact procedure to do it on this bike? Believe it to be a Kouksan 2K3 ignition. I already have the regulator/rectifier from trailtech.
Old 01-21-2023, 09:33 AM
slocalspode's Avatar
Default AC_DC conversion
We talked about doing the floating ground in this thread.
http://www.gasgasrider.org/forum/showthread.php?t=528
But there is more (better) info in one of my later posts.
I'll have to do some searching to find it.
There is a wire in the 2K3 stator you have to de-solder and
re-solder to another location on the stator.
Then make sure all of your electronics, (except the CDI), to
the battery + and - terminals.
Make sure the isolate the rectifier/regulator housing from the
frame and ground only to the battery.
Maybe someone can search my past posts and find it.
Good luck. Jeff
Old 01-21-2023, 10:38 AM
I've searched everywhere I can think of that I might have
posted the AC_DC conversion topic.
ThumperTalk, SuperMotoJunkie, KDXForum and ADVRider
I know nothing ever leaves the "WEB", but, I can't find anything
I posted about doing the floating ground conversion.
I also did a DC conversion on my KDX240SM without doing a
floating ground to it's stator....
I did this maybe 10 years ago and my feeble mind can not recall
the details.
Sorry.
Old 01-21-2023, 12:45 PM
Send me a private message with an email address.
I found two .pdf files. One from Trail Tech and another
from Baja Designs on how to do the floating ground
on a 2K3 stator.
If your 2013 GasGas has electric start, I doubt, these will
be of help.
the file sizes are: 2.03 mb and 1.47 mb.
I was searching on their web sites and could not find
either of these files there anymore. the must have deleted
them.
Good luck.
Old 01-21-2023, 05:33 PM
SS109 SS109 is online now
Is this the thread? http://www.gasgasrider.org/forum/showthread.php?t=1859
Old 01-22-2023, 09:47 AM
That is the one. Don't know why I could not find it.
I did not click the links to see if they still worked.
Edit: yup.... Looks like the links are dead.
If not, the OP can get a hold of me and I can forward
the two files I have.
Thanks SS109.
Tags
2013 300e, electrical, gas gas 300, stator
AC/DC conversion - FLOATING ground Bryan Enduro Electrical & Wiring 0 08-09-2020 08:41 PM
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Floating front Rotor Dirt Dud Enduro Chassis & Body 7 01-05-2017 11:59 PM
Estart require floating AC ground? Brian Enduro Electrical & Wiring 5 06-03-2013 01:29 AM
oversized floating rotor? wheels7 Enduro Chassis & Body 3 02-21-2007 10:25 AM
