#11
Have you measured the squish yet? You can do it through the plug hole if you are very careful. Use a long piece of solder and feed one end out to the cyl wall. Feed the other end to the opposite wall. This will leave a big loop out of the plug hole to hold on to. Rotate the flywheel as described in the article. The method in the article is the best way, but through the plug hole will give you an idea of how bad it is. If it is way out, then use the aticle's method before sending it off for machining.
http://www.gasgasrider.org/html/measuring_squish.html
2011 EC250E |
Help with Float Level - Low mileage EC250 2013 | periclesgsilva | Enduro Intake/Carburetion - 2 stroke | 10 | 07-06-2017 05:22 PM |
2013 EC300 E - GasGas Fan Rectifier/Regulator | FDB | Enduro Electrical & Wiring | 2 | 10-25-2014 02:10 PM |
what ever happened with the 08 ec300 christini? | dank | General Discussions & Announcements | 14 | 04-26-2014 05:31 PM |
New 2013 Christini GasGas AWD 5999? | Moto7man | New Bikes | 16 | 02-24-2014 10:47 AM |
Christini Gasgas | 2 strokes 4 life | General Discussions & Announcements | 33 | 02-17-2009 11:22 AM |
