Old 08-23-2020, 03:24 PM
Gas Guzler Gas Guzler is offline
Default Drz 400 Cylinder head on 450 fse
Hi has anyone else fitted a drz head on 450fse?
Mine destroyed the original head. ?Snapped valve?.
So I fitted a drz head. The bike was originally hard to start from cold ?2003? model but ok when hot. Now it?s the opposite.i suspect the compression is to high for the starter/ battery as it will start with jump leads, no chance on kick start.
Has anyone else done this conversion or had these starting issues?
Thanks for any info.
Old 08-23-2020, 09:14 PM
Make sure the compression release is working.
Sounds like it is sticking.
Old 08-24-2020, 04:21 AM
The auto decompressor seems to be working.its action is fine when stripped and appears to work when rebuilt. It?s very awkward to inspect when rebuilt.
I have fitted hot cams but can?t see why they could effect the decompressor.
Seems like the starter and battery are lazy.
A previous owner fitted a later flywheel cover with different starter gears to try and solve starting issues I believe.
Are the starters supposed to turn quite fast?
As mine is relatively slow even when cold.
If it doesn?t fire in first 3/4 attempts then the battery has not enough power but jump it and it fires straight up.
wtb ec 300 cylinder&head hookedongasgas Parts 2 09-12-2018 10:10 AM
S3 cylinder head motopsycho87 Enduro Engine - 2 stroke 22 10-22-2016 04:07 PM
Swopping 1997 Cylinder head with 2005 head EC250 Enduro Engine - 2 stroke 10 12-15-2015 10:13 AM
Coolant leaking through cylinder head socket-head bolts. GGRider01 Enduro Engine - 2 stroke 5 10-17-2015 07:38 PM
200 cylinder and head gasgasxc Parts 1 04-17-2015 11:29 AM
