Old 10-17-2015, 01:32 PM
GGRider01 GGRider01 is offline
Default Coolant leaking through cylinder head socket-head bolts.
Curious to know what to do. I just put the bike together and have ran it about 3 times for a few minutes each. I've had leaks at the coolant lines and have replaced a few hose clamps. The hoses are brand new. Then I noticed coolant collecting around one of these bolt heads.
The bike has never had copper washers installed since I've bought it. Would it be as simple as that to fix? As far as I can recall, the studs thread between the two o-ring head gaskets into the cylinder, so it would make sense for coolant to be able to travel up these bolts and out by the heads.
The gasket in the T shaped coolant return at the top of the cylinder is holding fine.
Old 10-17-2015, 04:39 PM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
Yes,an easy fix.The copper washers are sealing washers.
Old 10-17-2015, 05:13 PM
I feel silly. It was the hose leaking very slowly. More hose clamps!
I really like these Norma 21 hose clamps for their ease of use but they don't always get tight, especially with replacement hardware store hoses.
Old 10-17-2015, 06:58 PM
I once had a frog that would urinate on the head. Took a while to find the source of that leak!
Old 10-17-2015, 07:19 PM
TheLetterJ's Avatar
TheLetterJ TheLetterJ is offline
I hope you didn't do the "taste test" to verify if it was coolant!
Old 10-17-2015, 07:38 PM
gasgasman's Avatar
Maybe, if it was this....
Swopping 1997 Cylinder head with 2005 head EC250 Enduro Engine - 2 stroke 10 12-15-2015 10:13 AM
Help - Head Bolts? liv2day Enduro Engine - 2 stroke 33 04-16-2014 09:33 PM
Sealing Head Bolts -Coolant Leak EC125! kevells Enduro Engine - 2 stroke 6 07-16-2012 01:26 PM
Ec250 Cylinder Head Bolts? Elliker Enduro Engine - 2 stroke 8 01-24-2009 04:51 AM
Head bolts - no access? eff Enduro Engine - 2 stroke 14 04-12-2008 06:43 PM
