Old 08-17-2011, 09:26 PM
lankydoug lankydoug is offline
Default Green spark plug
Has anyone experienced your 2 stroke plug turning a greenish color. I've been using Sunoco 110 and Spectro SX oil. When I get the jetting close the plug is turning light green instead of cocoa brown. If it's rich it will be sooty and black and on pump gas it was cocoa brown but wanting to detonate from too low of octane. I'm going to try VP 110 and Lucas synthetic blend next but wondered if anyone else has had green plug color?
Old 08-17-2011, 10:39 PM
Timbre Timbre is offline
Default Maybe the lead in the Gas?
Sunoco 110 race gas has lead in it, so maybe that is why you are getting a different color on your plug?
Question: Do you have modifications on your bike that require that high of octane? If not, i would be surprised if you are detonating and therefore in need of that high of octane. High octane fuel burns slower, which stops detonation.
For what it's worth.....i am able to run 9 lbs of boost on my 2-stroke turbo snowmobile with only a 50/50 mix of 110 and 91 non-ethanol pump gas. A turbo is considered a substantial modification, so that makes me think that using straight 110 in your bike is overkill, unless of course you have some substantial mods. on it as well.
Maybe a little more info on the mods (if any) on your bike, what bike you have, the plug you have in it, jetting you are using, and what elevation you ride at would be helpful.
Cheers!
Spark plug? Pepperami Enduro Engine - 2 stroke 3 06-28-2011 01:49 PM
Spark Plug Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 18 03-02-2011 02:50 PM
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
EC 250 Spark plug Grampy Enduro Engine - 2 stroke 11 12-16-2008 12:24 AM
Spark plug gap???? Bandit9 Enduro Engine - 2 stroke 1 08-29-2007 05:26 PM
