Old 09-06-2011, 12:00 AM
EricP EricP is offline
Default How to remove main bearings and seals?
What's the best way to remove the main, crank beaing seals and the left side bearing? Screwdrivers? Special seal removing tools? I would like to hear how others are doing this.
Thanks,
Eric
Eric P.
SoCal MC
AMA D-37
2004 KTM 400 EXC | 2001 GG 250 MC | 2001 GG 200 EC (wife's) | 2000 Montesa Cota 315 | 1967 Lambretta Li 125 "Special"
Old 09-06-2011, 06:50 PM
Zeal Zeal is offline
When I have done this I use a heat gun on the case, then punch out the seals with a wooden punch or dowel.
Old 09-06-2011, 11:18 PM
PEB PEB is offline
The seals should come out with a screw driver I have baked the cases at about 300f for 20 mins. Take out with some hot mitts and slap the case on a cookie sheet the bearings will fall right out.
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
Sealed main bearings? hallam76 Enduro Engine - 2 stroke 25 03-16-2011 09:26 PM
99 ec300 front wheel bearings and seals barbwire44 Enduro Chassis & Body 3 04-01-2009 03:51 PM
Remove front axle BULTACOBRIS General Discussions & Announcements 2 03-10-2009 10:28 AM
Periodically remove and re-fit all bolts? stay_upright General Discussions & Announcements 2 01-14-2008 07:56 PM
