Old 10-05-2011, 07:40 AM
forgiven forgiven is offline
Default Overflow issue and bog
I went out to ride the bike the other day and it was bogging bad off the bottom end, once in the powerband all was good.
When I parked the gas was overflowing terribly...almost as if the overflow line couldn't keep up. It is a 2010 so I am pretty sure the needle and seat are fine...but I will check.
My question is that could extreme bowl height affect the off idle performance. It was working like a champ last time and it doesn't seem that bowl height would play into it...hence the question.
I anxiously await the myriad of answers...
Old 10-05-2011, 07:49 AM
eff's Avatar
eff eff is offline
Bog of bottom like that suggests a lean pilot circuit. The confusing thing is that you seem to have a float needle issue which should make it rich. I assume you know your jetting is good for the cooler temps we are having now so I would focus on your float/needle setting.
If you have not been doing anything to treat the ethanol in the gas then that may be the issue with your float needle. I would pull the carb and check your float height and look at the needle. If in doubt just replace it.
2004 GasGas DE250
Old 10-05-2011, 08:31 AM
I raised my pilot from a 40 to 42 or 42 to 45...can't remember...only 2 weeks ago and it ran great. I am pretty sure jetting is pretty dang close.
I am just wondering if it is TOO rich and if the bowl height has anything to do with that. The gas is about 2 weeks old, and I put stabil in it at the time. I have needles that leak and this isn't that...I is POURING out the overflow
Old 10-05-2011, 08:42 AM
eff's Avatar
eff eff is offline
OK, so it seems like nothing should be wrong, but overflow really bad. I would still pull the carb and inspect the float needle. You could test by connecting the supply line to the carb and open the fuel petcock and see if you can stop the flow of fuel by moving the float. If not, your problem is probably that the needle isn't seating right , if so then you may have a bad float.
Of course do this in a well ventilated area over a bucket.
2004 GasGas DE250
Old 10-05-2011, 09:20 AM
K...thanks
Powervalve issue? SpeedyManiac Enduro Engine - 2 stroke 222 11-01-2023 07:03 PM
Coolant overflow bottle 2000 EC300 ... help BazzabikesMK United Kingdom 1 07-23-2011 04:12 PM
Low down / tickover issue HELP stevehipkiss Enduro Intake/Carburetion - 2 stroke 9 02-14-2011 09:03 AM
new GG member with some GG questions powervalve breather and overflow bottle swazi_matt Enduro Engine - 2 stroke 8 02-04-2011 10:24 AM
Radiator Overflow geraldh Enduro Engine - 2 stroke 5 10-04-2009 09:23 AM
