Old 11-24-2011, 09:50 PM
jayc jayc is offline
Default Keihin PWK #5 slide --> #7
I am convinced that my '02 125xc's chronic fart off the bottom is the result of a too-rich slide. It's Keihin PWK has a #5 slide. I want to make it into a #7 (with a little dremel work). Anyone have directions on what to take off?
Thanks - JayC
Old 11-24-2011, 10:41 PM
GMP's Avatar
GMP GMP is offline
I think thats too lean. Why not try a #6 first, borrow one if possible before cutting yours. You can't go back once you cut.
Old 11-25-2011, 07:26 AM
Once I figure out how to calibrate the slide cutaway, I will surely take it off a bit at a time. I think ALL of the later model Gassers use #7 slides. I read a post by somebody that mentioned #6 is stock on the '02 125 (and that it is too rich). Why mine has a #5 in there is beyond me.
It's pretty rich through that range - idles clean and had good throttle response right off idle (45 pilot), but burbles and is weak at low throttle input (which where I am most of the time). It loads up after a while, then smokes like a 70's vintage DDT truck once I open it up until it clears out once on the high needle (unmarked LTR, I think) and main (162). The high-end is very close - throttle response is adequately snappy, and it screams like a raped ape and pulls hard at WFO.
Another friend suggested borrowing a slide too - as I told him, not only do I not know anyone with a spare slide, I don't even know anyone who owns a dirtbike any more!
Thanks - JayC
Old 11-25-2011, 09:30 AM
MJC MJC is offline
Jay, Changing the slide cut away is really easy to do. I've done it a bunch of times to different bikes. It effects the transition off the pilot and onto the needle. Which sounds like the area you are describing.
The difference between a #5 slide and a #6 is 1mm or .0040 of an inch.
here's what you'll need.
1- vernier caliper.
2- a black magic marker or dykem blue for marking the slide where you what to FILE it.
3- half round file. Like this http://www.amazon.com/Reciprotools-R..._bxgy_hi_img_c I don't recommend a Dremel tool unless your really good with it. They simply cut too fast for a lot people.
4- 300 grit sandpaper
Remove the slide. Locate the halfmoon shaped cut out,located on the air filter side of the slide. Take your marker and mark about this much [ ] above and around the entire outer most edge of the halfmoon. Next take your calipers and scribe a line, .5mm would equal a #5.5 slide or 1mm would= a # 6 in your case ,around the outermost edge of the halfmoon all the way around it. Now you will want to take your hand file and blend, keeping the same angle of the slide, up to the line that you just scribed. Take the sand paper and sand the edge of the slide you just filed until it's nice and smooth, you shouldn't be cutting with the sandpaper, just smoothing. Thats it. Now reinstall the slide back into the carb.
Old 11-25-2011, 10:47 AM
Thanks! I thought the measurement as you described was the case, but wasn't absolutely sure.
Just so I'm clear, do you re-bevel the whole curved area under the slide so that the cutout is a straight line from the new cut to the front of the slide (increasing the angle of the cutaway), or curve the new cut into the existing area on the bottom. I'm thinking the former...
JayC
Old 11-25-2011, 01:06 PM
MJC MJC is offline
JayC
I'm not sure what you mean by Under the slide? Nothing under the slide is getting cut. The cutout should look exactly as it does now,the same tapper, but 1mm wider all the way around it. If it's done right no one will even know it been cut.
Old 11-25-2011, 01:27 PM
I'm referring to the taper that is on the bottom of the side, which I guess is the actual cutaway.
Like this:
First would be original, second is a re-taper (I'm assuming this is what I want), and third would be opening up the intake side, but preserving the taper under the slide. Clear as mud?
JayC
Old 11-25-2011, 05:23 PM
MJC MJC is offline
Like this:
JayC
It should look like the first drawing. Your not changing the taper. You're just making the opening of the cutaway a little bit larger all the way around.
Old 11-25-2011, 08:41 PM
I'm surprised no one else has mentioned it, but another work around is to alter the needle diameter to change the transition from the pilot onto the needle. You will need to retune your pilot circuit a bit to achieve this though and depending on how far out the slide cutaway is it may or may not solve your issues.
Old 11-25-2011, 09:27 PM
GMP's Avatar
GMP GMP is offline
The '02 XC125 we had came wit a #5 slide. I worked out some jetting with DGH needle that worked well, thought I gave you the specs at one time. #6 maybe, but #7 seems quite lean for a 125. The 250s like the #7 with a much bigger signature.
Keihin PWK Needle Chart MattR Enduro Intake/Carburetion - 2 stroke 29 05-25-2021 11:01 PM
KEIHIN float valve nhrider Enduro Intake/Carburetion - 2 stroke 1 06-17-2008 01:10 PM
Keihin Carb Harry Enduro Engine - 2 stroke 4 05-30-2007 06:52 AM
