Bleeding clutch!
I fitted the Gasgas clutch saver and when I was fiddling and pulled the clutch lever it spewed it's fluid. Now I have fitted it properly I'm having trouble bleeding the system. Any tips would be much appreciated, Cheers.
2005 EC 200 |
Just open bleeder bolt enough and let fluid run about 2-3 times reservoirs capasity. Keep reservoir filled all the time. Then close bleeder, fill reservoir cup and close coverage.
If clutc needs bleeding after that do it again. Remember to use mineral oil - not any dot brakefuids! If you don't have mineral clurchfluid available 5W fork oil works fine.
There is no such thing as bad weather! Only riding gear is improper or insufficient When it hurts you know you're allive! Gas Gas EC 300 Factory Racing 2012 - Ohlins TTX both front and rear - Rekluse Core EXP 2.0 + Rekluse clutch basket - Scalvini full exhaust system - S3 Head - Trusty adjustable PV cover That was ultimate setup for me... Now trying something else for a while... |
AJP M/C use DOT 4 break fluid
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
I'm using DOT 4 fluid is that wrong?
2005 EC 200 |
It is written on the master cylinder which type of fluid is required. My 03 uses DOT 3 or DOT 4.
Why cant I bleed it?
2005 EC 200 |
Here is how I bled mine after rebuilding the master cylinder.
Turn bars so the MC reservoir is almost level and small bubbles in the intake hole are not trapped. They will bubble up the the surface when the lever is squeezed 1/4 inch. 1. open bleeder at slave cyl. 2. squeeze clutch lever and hold it while you tighten the bleeder. repeat steps 1 and 2 until you get only solid fluid from the bleeder. 3. barely depress clutch rapidly causing tiny bubbles (if present) to surface in master cyl. reservoir. Never let the fluid level get low enough for the MC to gulp any air. If all is well with your system this whole process should take less than 5 min and require you to top off fluid level 2 or 3 times. |
I've always bleed mine from the bottom up. I use some clear plastic hose, zip tie it on to the bleed nipple, clean stringe and push fluid from the bottom up with the master cylinder cover off. Then I take an other stringe and vacuum out the old "dirty" fluid. I use this method for clutch and front and rear brakes.
I have found this method works best, as you do not let any air into the system. I also put a "loop" in my hose from the stringe to the nipple. Good Luck
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
I should have added to make sure your lever has a small gap before it starts to move your MC piston. If it doesn't it will not intake fluid properly and even if you somehow get it bled it can cause the system to pump up and or feel spongey. This also applies to the front brake.
Gas Gas EC 300 '06 BMW F650 |
Clutch bleeding - how to | swazi_matt | Enduro Engine - 2 stroke | 2 | 08-09-2011 02:57 AM |
Bleeding hydraulic clutch...new line | blanc | General Discussions & Announcements | 7 | 04-12-2011 03:56 PM |
Bleeding Rear Brakes | GMP | Enduro Chassis & Body | 6 | 11-16-2009 09:00 PM |
46mm Ohlins Bleeding | PEB | Enduro Suspension | 15 | 04-23-2009 07:22 PM |
HELP! - bleeding hydraulic clutch | SpeedyManiac | Enduro Engine - 2 stroke | 6 | 10-10-2008 07:12 AM |
