Old 02-23-2012, 03:08 PM
Vinny's Avatar
Vinny Vinny is offline
Default Eldor coil . Why two different ones ?
I need a coil for my 450. Pulled the old one off. The # is MFS400380006
I wonder why I dont have a 450 coil.
Vinny
Austin , Tx
A wonderfully working and hard riding '05 GG 450.
Old 02-24-2012, 03:30 AM
Vinny's Avatar
If anyone knows of a coil for a 450 for sale please PM me, I would like to buy it. Thanks.
Vinny
Austin , Tx
Old 02-23-2015, 10:29 AM
Edm11 Edm11 is offline
Not sure if my pm's are working. I know this is an old thread, but if you still have that coil for sale I need to buy it. Part # mfs400380006
Thanks
Old 02-24-2015, 11:00 PM
Found... Thanks Vinny !
Old 03-02-2015, 01:26 PM
Was wrong part, I need MFS450780006 if anyone has one, thanks.
Old 07-09-2015, 05:30 AM
gazgaz gazgaz is offline
Hey guys,
I've been scouring the internet for solutions to a no spark problem on an 05 fse 450, and I've tried a bunch of different things. Everything seems to be perfect, other than the fact I'm not getting a secondary resistance reading through the coil. One fella I called said this is normal, but everything else I've read says otherwise?
I'm hoping to buy one, but was hoping you guys might be able to shed some light on the matter first.
Thanks!
Old 07-10-2015, 04:03 PM
Vinny's Avatar
Originally Posted by gazgaz View Post
Hey guys,
Thanks!
PM with suggestions sent.
Vinny
Austin , Tx
Old 07-29-2015, 08:14 AM
Tafka Tafka is offline
Has anyone tried to replace the FSE450 ignition coil with VAG group(VW/Audi/Skoda) ignition coil? By the appearance they are the same and the plug should be the same. If anyone has one coil to measure, then share the results....length etc.
Example:
Old 09-01-2016, 03:38 AM
Okay i went on a limb and bought one VAG group ignition coil (part 036905715), as on above picture. Measurments are all the same, plug fits but the wire order is little bit different. So reorderd the pins but still no spark
Are the inside electronics really this different that you can't get a spark? Or is it possible i got defective coil from shop?
It's crazy how GasGas wants 150-200 euros for original coil and car coils cost 20-30 euros :S
Old 09-05-2016, 07:39 AM
Would MFS450780006 ignition coil work on older models?
MFS450780006 is for 2007 and up models so it would be for Kokusan ECU.
But it has built in igniter like older one. It has 3 pins vs 4pins but usually 4 pin ones have 2 grounds.
So i'm wondering if Kokusan and Magneti Marelli ECU-s have the same triggering signal? I think Marelli has 12v trigger signal for ignition?
testing lighting coil bonkeye Enduro Electrical & Wiring 7 05-09-2012 07:51 PM
FSE Coil-on-plug ohm readouts? bergerhag Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-20-2008 03:05 AM
Coil? bronco-hunter Enduro Electrical & Wiring 0 07-28-2008 06:48 PM
