Old 03-13-2012, 09:52 PM
mwoody98 mwoody98 is offline
Default 2008 EC300 clutch assembly position
I recently purchased a 2008 ec 300 the kick starter shaft spline was messed up so
I pulled the clutch cover off and being to hasty to get the kick start shaft out I pulled the
center clutch hub off the primary shaft forgetting to mark the location.
Then reading a manual I found on line later I see a note that the hub has an assembly position.
Now i am scared to put it back together because I have looked and looked for a factory mark indication of any type and see nothing.
Can anyone help me so I know how to reassemble the center clutch hub onto the primary drive in the correct location..
thanks in advance for your help with this.
Lesson learned mark everything even if you do not think it is important..
EC125 2008 clutch fiber plates Leon_gasgas Enduro Engine - 2 stroke 6 12-07-2011 03:59 AM
Looking for a clutch master cylinder assembly... SpeedyManiac General Discussions & Announcements 5 05-09-2008 07:06 PM
