Old 03-27-2012, 12:24 PM
solstice solstice is offline
Default Newbie question 300 throttle response
Guys
I don't have a clue about 2 strokes, so wondered whether anybody can give me some advice, i have just bought an 07 300, the response off the very first part of the throttle isn't very crisp, it seems to fourstroke and then clear and pull well, any ideas as to how I remedy?
Ta
Old 03-27-2012, 01:26 PM
stainlesscycle's Avatar
adjust airscrew, or possibly needle position....
07 ec300
www.stainlesscycle.com
Old 03-27-2012, 03:07 PM
hannesd hannesd is offline
or maybe pilot jet too rich... quite some possibilities
but first things first, start with a fresh spark plug...
Old 03-27-2012, 04:08 PM
First things first, take the time to have a peek inside the carb and see whats currently inside it. Pilot, needle and clip pos, and the main. Then list up your elevation and temp.
As everyone else has said pilot &/ needle pos or taper. Chipped reeds will also make things rich off the bottom end so if its only just something thats started I'd consider checking them. You may as well clean the whole carb out when doing this as it'll be out of the bike, and checking your float levels.
Quick question. Does the bike idle? and is the idle adjustment screw wound right in against the carb side (spring all bound up)?
Old 03-28-2012, 02:29 AM
Thanks guys, the bike is new to me (and thinking about it the fella I bought it from said he ran it slightly rich) so has been like this since I've had it, it idles fine no issues there.
Will take a look at the carb.
Old 03-28-2012, 02:41 AM
If it idles well and has good off idle response the first change I'd be making is to lift the clip up 1 position on the needle.
Old 03-31-2012, 07:31 AM
Thanks Jacobi, the needle was in position 3 and I moved it to 2, the bike starts better and the "four stroking on initial throttle opening has improved but not disappeared, I've heard going to pos 1 will make it run too weak but might give it a go just to see what effect it has on a quick spin up the road.
Old 03-31-2012, 03:34 PM
Give it a go. If its the stock needle you will never totally clean up the bottom end. You'll also expect a certain amount of burble on the pilot jet (very small throttle opening) which should clear up as soon as you're on the needle.
Old 04-01-2012, 12:10 PM
Is there an alternative needle which sorts the bottom end?
Old 04-01-2012, 03:46 PM
Like I said, take the time to see whats in there before you start worrying about which direction to head. The jetting section of this forum is filled with loads of info.
Newbie Handling Question rxmx General Discussions & Announcements 18 10-11-2011 11:52 PM
Throttle question '11EC300 Enduro Chassis & Body 2 06-27-2011 05:08 AM
Spot connect emergency response nambo-trev Enduro Product Reviews 0 05-31-2011 07:37 PM
My response time and my future... webmaster General Discussions & Announcements 34 03-10-2011 12:49 PM
Wrist Pain & Thumb Throttle Question RPB111 Injury & Recovery 8 10-22-2007 05:55 PM
