Old 06-15-2012, 07:53 AM
Biff's Avatar
Biff Biff is offline
Default Handle bar choke
My choke cable holder chewed the threads on the carb. Apparentlly when you pull the lever it pulls the cable sideways where cable enters carb. Spoke to dealer and he said they use the old carb mounted choke. Had to use hi strenght adhesive to bodge fix as I'm out tommorrow 140 + miles
Biff
Old 06-15-2012, 08:48 PM
andoman's Avatar
andoman andoman is offline
Thanks for the report, I'll check mine.
I hope this isn't common as I really like the handle bar mounted unit.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 06-15-2012, 09:27 PM
GMP's Avatar
GMP GMP is offline
Mine will join the plastic sprocket cover and a few other things in the junk box.
Old 06-15-2012, 10:20 PM
GasGas's Avatar
GasGas GasGas is offline
I had the pleasure of a stuck throttle last night, and upon dis-assembly of the carb I noted that the top of this choke plunger had packed with grit and dirt. Most likely cause of the problem. I will be making the switch to the standard plunger. Also installed in line fuel filter. What do you guys use as a filter for your carb vent lines when moving the upper lines to the air box?
2018 EC 300
Old 06-16-2012, 09:53 PM
GMP's Avatar
GMP GMP is offline
"Carb vent hose inline filters" from here:
http://www.kevinscycleracing.com/
Choke cable eliminator gasgasman Enduro Product Announcements 28 05-09-2011 09:43 PM
choke cable help???? nambo-trev Enduro Intake/Carburetion - 2 stroke 2 08-27-2010 09:23 AM
Cable choke for 03 250? marjastaja Enduro Intake/Carburetion - 2 stroke 3 02-28-2010 09:45 AM
Leak from around choke PEB Enduro Engine - 2 stroke 0 08-16-2009 10:16 PM
