Old 10-23-2012, 09:21 PM
Default EC200 Engine Mounts
Hello wise people,
I'm curious if anyone knows if the engine mounts are different between the EC200 chasis and the 250/300 Chasis. Particularly speaking 2013 models here too!
I'm considering buying a 2013 EC200R but I'd like to have the option to transplant/swap engines between chasis with my 2010/2011 frame if I find myself preferring certain attributes of one or the other more. Will it be as simple as pulling the lower mounts on each and dropping the engine in? They use the same engine cases so realistically not much will be different there, and the 2012 and 2013 have dropped the headstay which is where I imagine they would be a bit different maybe?
Thanks
Jake
Old 10-23-2012, 10:35 PM
twowheels's Avatar
Hello wise people,
Thanks
Jake
Well, not exactly the same cases. The center cases are different to make the essential air-pumping function work out. Pipes are different too, although I would bet a dollars worth of donuts that the mounting points on the frame are the same.
Steven Beane #275
afterhourscycle.com
Old 10-24-2012, 12:45 PM
GMP's Avatar
GMP GMP is offline
Its been the same on the older bikes and engine swaps have been done. '99 to '04 and '05+ are different. Like Steve says you would need pipe(s) for correct performance, '12/'13 is different than '10.
Old 10-24-2012, 05:56 PM
Sounds great to me! What is the difference in the pipes for 2012 Glenn? Anything visibly different, or just the mounting point at the frame?
I'm really not considering doing a swap, but just building an argument (pro's) to why I should buy a new 200. If you have any other reasons why I should feel free to feed the fire.
Bar mounts which hole peanutsracing1 Enduro Chassis & Body 22 03-01-2011 03:26 PM
Engine mounts on to frame west aussie gas 450 Australia & New Zealand 3 01-28-2007 08:16 PM
Which mounts better - GPR or Scotts Roy Salmon Enduro Chassis & Body 3 01-25-2007 07:45 PM
engine mounts on to frame west aussie gas 450 Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-26-2006 08:59 AM
