Old 12-09-2012, 06:49 PM
phoenix's Avatar
phoenix phoenix is offline
Default 2T/Gas Gas Newbie Question
I have only ridden four strokes and my 2013 Gas Gas 300 is my first foray into the two stroke world. With that being said, there is a noise that comes from the bike that makes me curious. It sounds like when you open your throttle and let it slap shut...like the slide on the carb whacking shut. It happens when I'm on the gas, though, not necessarily when I close the throttle. I'm sure you're all snickering because its something obvious, but can anyone enlighten this 2T newbike as to what the noise is (and is it something to worry about)?
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 12-09-2012, 07:14 PM
*snicker snicker*
They are pretty noisey engine. Its hard to know exactly what you are hearing though. The PV is a very basic design which needs clearance to allow for carbon build up. This will 'clack' as it rattles a bit. Its more common in the lower rpm. You'll probably also want to check the preload on the PV plate from the actuator arm. Some are a bit slack from the factory and you'll pick up some bottom end performance by getting it right.
It could also be excess fuel being burnt off in the pipe. Its not uncommon for them to knack a bit at part throttle or when letting off from higher rpm.
Does it happen on the stand or when you're riding?
Other strange sounds that you might hear are the pipe springs/header vibing against the spigot. The bashplate vibing against the frame. I even get the brake pads rattling against the disk when they wear out. Any chance you could post a video?
Old 12-09-2012, 10:01 PM
andoman's Avatar
andoman andoman is offline
Default Check for PV Slop
Exact same sound I had. Tightening up the PV linkage all put eliminated the sound. I didn't really put any pre-load on it, but just took out the slop. There is a great pinned thread on the subject.
I'm with Jakobi on the other sounds for overall annoying "noisiness." Quiet the singing exhaust springs with a short length of tubing slipped over each one. At the earliest convenience toss the stock exhaust o-rings for viton units.
While we're talking exhaust: I isolated some vibs from engine to frame by cutting about 5/8" off both the exhaust stinger and the lower end of the silencer pipe. My silencer pipe doesn't slip into the stinger any more. There is about a quarter inch separating them inside of a 3 1/2" length of heavy duty heater hose. The exhaust pipe and silencer are both free to move independently.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 12-09-2012, 10:20 PM
phoenix's Avatar
Thanks to both of you. I've mostly noticed it on straightaways when I get on the gas but then let off the throttle a bit. It doesn't seem like a vibey noise...more of a clack. I'll find that article about the powervalve and shoot a vid if that's not the culprit. Thanks for the other noise tips as well.
2014 Gas Gas XC 200
Old 12-09-2012, 10:28 PM
bowhunter007's Avatar
bowhunter007 bowhunter007 is offline
once you identify the little noises that go along with your new bike, you'll only really notice them...when they stop.
All healed up, and ready to burn some fat.
Old 12-10-2012, 03:19 AM
I broke my front pipe mount off yesterday! Its noisey now.
Old 12-10-2012, 05:08 PM
LAWMAN's Avatar
LAWMAN LAWMAN is offline
sounds like the dreaded "power valve clack" to me. I wouldn't worry about it unles it stops....
Old 12-10-2012, 05:18 PM
roostafish's Avatar
roostafish roostafish is offline
With the Q Stealth, every little mechanical noise is accentuated. With my new bike, all I hear is booming noise from the muffler. It's not that loud, but it's a heck of a lot louder than a two stroke with a Q Stealth.
Mike Sheetz
OMRA #21AA
What will I be riding next? Christini GG 300?
'15 KTM 300 XC-W
'08 EC 250 (Gone to new happy owner)
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 12-10-2012, 05:47 PM
Banned
My 12' is now doing this, it's more of an anoyance then anything.
Newbie question 300 throttle response solstice Enduro Engine - 2 stroke 15 04-13-2012 05:18 PM
Newbie Handling Question rxmx General Discussions & Announcements 18 10-11-2011 11:52 PM
Newbie FAQ Brian Suggestion Box 0 01-27-2010 01:35 PM
Help for a newbie? almajeremy Enduro Intake/Carburetion - 2 stroke 2 03-08-2009 02:27 PM
Newbie here c-152 General Discussions & Announcements 2 04-03-2008 08:59 AM
