Old 08-23-2007, 01:50 PM
jimbolaya's Avatar
jimbolaya jimbolaya is offline
Default LT racing jet kit report...
Hey all,
Just got my jet kit in from gofasters and I can say "BULLY!". Things have cleaned up nicely from1/8 to wide open. I still have some sputter from
closed to 1/8 so I reduced the pilot to 45 from 48 (airscrew at 3 turns out).
It's better, but I want perfection so in will go a 42 asap. Then I should be able to run the A/S at about 1 1/2 out. all the sputter is gone from the previously sputtered up throttle positions. Yah Whoooo!!! I also swithched to the sunny setting and WOW does this 300 go. I love my gasgas mucho better now!
Jimbolaya
06 EC300
Grab life by the bars and twist!
Old 08-23-2007, 02:01 PM
eff's Avatar
eff eff is offline
Jim,
I usually drop the needle one spot (clip up one) to remove that sputter. What position is the clip in?
Old 08-23-2007, 07:11 PM
jimbolaya's Avatar
Hey Eff,
the clip is in the middle position as requested by instructions. I didn't think dropping the needle would clean up the off idle richness that's one reason it isn't already done. thanks for the tip. I'll try that first.
I heard from my local gasgas dealer not to run below a 45 pilot, but if I can't get the airscrew below 2 1/2 turns out I've lost the adjustability of the airscrew to lean out that circuit. I will report back how that adjustment goes.
thanks!
Jimbolaya
06 EC300
Old 08-23-2007, 08:34 PM
GMP's Avatar
GMP GMP is offline
Try an #8 slide if it won't clean up with a smaller pilot.
Old 08-24-2007, 06:35 AM
eff's Avatar
eff eff is offline
Originally Posted by jimbolaya View Post
Hey Eff,
thanks!
The instructions are based on 60ºF I believe. Refer the the std jetting chart in the manual to change from there.
I was running the 48 pilot, air screw 3 turns and the clip in the middle. I took my bike for a spin after I put on the LTR 126MM links (a couple of weeks ago). It sputtered, and was clearly running rich. I popped open the carb and raised the clip one and turned the air screw to 2.5 turns and things ran smooth.
Old 08-24-2007, 09:18 AM
jimbolaya's Avatar
took it out after dropping the needle 1 position. temp around 80. with the a/s 3 turns out it was very close, but I'd still liketo drop the p/j to a 42 and run the a/s about 1 1/2 out which give me latiude for adj either way. I must say over all this jetting set up is very good. thanks Les Tinius!
jetting when I'm finished should be as follows:
mj=178
pj=42
jneedle=2nd position from top
a/s= ~1 1/2
#7 slide
Jimbolaya
06 EC300
Old 08-24-2007, 10:30 AM
jeffd jeffd is offline
This carb is fine up to 3 turns out on the air screw. Les told me that this carb is designed to have the airscrew in that range. I believe he was told this by sudco (keihin importer for u.s.).
Old 08-28-2007, 05:40 AM
jimbolaya's Avatar
With the 42 pilot and airscrew at 2 1/2 turns temps at 84 deg. the carburetion is more clean, but just after cracking the throttle open it doesn't sputter it's more like a raspy hesitation (It may be just part of the characteristics of the engine). I put boyesen dual petal power reeds on my 200 and that same situation cleared up. Maybe since I have the v force3 reeds it is causing the same lack of super smooth acceleration at barely open throttle position (I don't know)
I do know that everywhere else is awesome. smooth powerful acceleration!!
Jimbolaya
06 EC300
Old 08-28-2007, 07:36 AM
GMP's Avatar
GMP GMP is offline
The reeds shouldn't do that, mine runs smooth and clean off idle. Try the #8 slide, borrow one if you can. Start back up to 45-48 on the pilot and middle needle position. The 250s seem much eaiser to dial in with a #7 than a #6. The 300 being a bigger pump may be eaiser with the #8. If the slide is rich the rest is a PIA.
Old 08-28-2007, 08:40 AM
jimbolaya's Avatar
Much thanks I'll give that a try!
Jimbolaya
06 EC300
2010 ec 300 report gg3 Ride Reports 18 05-16-2010 11:07 AM
WEC report - Gas Gas stay_upright General Discussions & Announcements 2 07-23-2008 07:00 PM
wec race report fury1 Ride Reports 4 08-21-2007 06:56 PM
'07 ride report?? GMP Enduro Engine - 2 stroke 11 07-06-2007 06:13 PM
Rebuild Report PEB Enduro Engine - 2 stroke 0 12-12-2006 12:44 PM
