Old 08-25-2007, 03:19 PM
gasgasman's Avatar
Default How to set float level. Revisited.
A while back, I posted a link on how to set your float level.
I finally found it after a long search.
Here it is again for those that need to have their's reset..
http://www.dirtridersinternational.c...?TOPIC_ID=2292
Old 02-07-2008, 09:01 PM
gasgasman's Avatar
For some reason the photos won't come up.
Here they are in the order that they appear in the instructions.
(Float assembly pivot pin not shown.)
(Fuel inlet needle shown with Viton (rubber) tip. The Viton is used to isolate the fuel inlet needle from vibration and to create a better seal against the fuel inlet valve seat.)
Old 04-24-2008, 11:15 AM
jyellard jyellard is offline
The first link no longer works.
I have checked and adjusted float level on other carbs, so could someone post some basic instructions with dimensions?
Thanks,
Josh
Old 07-08-2008, 07:58 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Try this http://www.keihin-us.com/am/_media/pdf/slide_valve.pdf
Float height is mentioned on the right.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 04-11-2009, 11:12 PM
Treesmacker Treesmacker is offline
Thanks,
Josh
The float Height should be 16mm from the bowl mounting face to the top
of the float as shown in the picture.
Old 04-28-2010, 11:42 AM
ec300 dave ec300 dave is offline
Default help on float height
Hi can anyone advise me on the correct float height for my year 2000 ec 300.
Old 04-28-2010, 03:59 PM
stainlesscycle's Avatar
16mm to the best of my knowledge.
07 ec300
www.stainlesscycle.com
Old 04-28-2010, 05:02 PM
eff's Avatar
eff eff is offline
Sounds right, but a rule of thumb is to have the seam in the float parallel to the carb body.
2004 GasGas DE250
Old 04-28-2010, 11:15 PM
moto9's Avatar
moto9 moto9 is offline
I set the floats on my GG by simply tilting the carb and closing the float gap until it stopped puking fuel at a 20 to 30 degree angle, then took a test ride and checked it at W/O.
May sound stupid bit it works.
A friend has a 09 that still drools when on the side stand.
Old 10-04-2010, 10:19 AM
Klausen Klausen is offline
Do this guideline also work for the newest generation of PWK.
I check my PWK 38 today - the float look totally different - only plastic no metal.
The GG 300 2009 Nambo is leaking on the trailer.
The float hight was 11mm - now I go to 14mm.
I can't test it until now.
My shock is in service.
Husqvarna TE 300
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
Rear wheel spacers revisited. Ud_luz Enduro Chassis & Body 9 09-13-2010 08:01 PM
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
Fork oil level ? Brian VT Enduro Suspension 4 03-10-2009 08:57 PM
WP Fork Oil Level MattR Enduro Suspension 11 08-02-2006 10:40 AM
