Old 03-05-2013, 03:57 PM
whodat's Avatar
whodat whodat is offline
Default 2005 to 2011 transformation
bought the kit and am pretty happy but I can not figure out the seat mechanism. Can anybody help with a picture or diagram? thanks in advance!!!
Old 03-05-2013, 04:34 PM
Fred1956's Avatar
Fred1956 Fred1956 is offline
The seat bolts down to the subframe, there is a red colored washer that protects the seat cover I believe.
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 03-05-2013, 05:56 PM
whodat's Avatar
OK then I guess the plastic parts are connected to the headlight. I thought the seat was just a bolt on item. Thanks for the reply.
Old 03-09-2013, 10:34 AM
whodat's Avatar
Default Help!!
OK, new question for any body that has performed the transformation. What to do with the air cleaner? My kit came with air cleaner cage and springy thingy retainer. I assumed I was to reuse the boot and two metal pieces which clamp together but they don't seem at all compatable, that is; the new cage has three post which do not align with anything from the 2005. BTW got the transformation kit from greenland racing out of spain.
Old 03-09-2013, 11:08 AM
Banned
Did you recieve a new airbox with your kit? The cage with the three posts is for the new style air cleaner and box.
Old 03-09-2013, 05:45 PM
whodat's Avatar
responded to your pm and yes it did come with airbox but no boot. I assumed I was to reuse old one but the metal part that connects the boot to the box is not right and there are no provisions for the three plastic prongs that came with the new filter cage. I see you have a 2012 and a 97. I think the 97 can be updated with a relocation of the coil and a new gas tank. Might want to do some home work on that one though.
Old 03-09-2013, 06:24 PM
Banned
I Have a late model tank already for the 97'. To do the update I have to move the coil as you stated and also I believe the water intake on the head needs to be milled down, because it sticks up so far. Im waiting for my wife to beat the crap out of the plastics on it already. And judging by last weeks ride it won't take very long!
Old 03-10-2013, 05:28 AM
Tigger52 Tigger52 is offline
When I did mine using the same kit I used the metal plate from the old airbox and drilled holes through the new one so I could bolt it up tight. A bit of a bugger to mark up the holes but just take you time and then enjoy the fiddly job of getting the nuts on the threads!
Like you I couldn't work out how to use the red bar and spring so I'm just using the old bolt through method -works absolutely fine.
Old 03-10-2013, 05:39 AM
hawaiidirtrider hawaiidirtrider is offline
Thumbs up
Thanks for the thread! watching and seeing whatever works and doesn't work for this kit.. all info is appreciated.
Old 03-12-2013, 04:59 PM
whodat's Avatar
OK, got every thing to work. Had to fabricate a metal adapter. It mimicks the retaining ring on the out-side of the box/boot junction for the OD and mimicks the filter cage regarding the ID. Drilled three holes which line up with 3 prongs on the cage and was able to use the spring loaded retaining device. Could'nt let a cool red anodized part go to that one drawer in the tool box, you know the parts graveyard from bikes gone past. There is something missing in the kit, however if you look at the parts diagram the only thing that stands out is a restrictor plate with 3 slots for the prongs on the filter cage. If you know someone with a newer bike you could look at.........
2005 VS 2011 Shock celler Enduro Suspension 2 03-03-2013 07:47 PM
Gasgas transformation kit Crombie General Discussions & Announcements 2 03-01-2013 04:27 PM
2005 to 2011 estart conversion forgiven Enduro Chassis & Body 1 01-17-2011 07:34 PM
Modded 2005 DE250 vs Stock 2011? AZRickD General Discussions & Announcements 1 01-10-2011 11:29 PM
Why Upgrade from a 2005 to a 2011? celler General Discussions & Announcements 36 10-18-2010 05:45 PM
