Needle N3CJ required in UK?
Hi, As title, wheres best (cheapest) to get the Yamaha Needle N3CJ everyone talks about. My 2010 runs ok but with the needle fully dropped, pos1, and the air screw at 2.5, But its not ideal...
Sam |
Sorry, I don't have a part # though :-/ |
Second that. Get it through ktm. Much cheaper.
KTM Product Code: 54731034600 |
Cheers lads, got one on order
Look forward to trying it... |
Get ready to hold on
needle
Any news on needle and set up.
Quick update. As a whole loads better! It is now clean right from idle all the way up to full chat. Much more compliant on the technical sections which was my main priority.
My only concern was during a meeting last week, after being flat out like on a long stretch or in crossing some of the nightmare bogs it became a little bit weak. Not to the point of 'pinking' badly just a bit flat on power. But sharpness soon came back. So what in the carburation can cause this. I'm thinking float level or main jet? I'm running a 175 main jet and thinking about trying a 178 or even a 180... But as I say, a vast improvement |
Slightly lean somewhere if its starting to fall flat when worked hard. Make one change at a time, but most likely it'll be on clip position. No harm in jumping up a size or two on the main though, and it will be noticable from 1/2 throttle onward.
Where did you get it from in the end?
2012 300ec 42p N3CJ#3 175m | nato | Enduro Intake/Carburetion - 2 stroke | 16 | 06-04-2013 06:16 PM |
Help required!! | brenduro999 | Enduro Intake/Carburetion - 2 stroke | 11 | 05-28-2013 04:42 PM |
EC 300 clutch required | justsam | Enduro Engine - 2 stroke | 0 | 05-15-2013 09:51 AM |
What needle is half clip richer than N3CJ ? | mariogt | Enduro Intake/Carburetion - 2 stroke | 3 | 12-09-2012 04:04 PM |
n3cj | bones150 | Enduro Intake/Carburetion - 2 stroke | 5 | 07-18-2012 08:13 PM |
