Old 06-27-2013, 01:32 AM
roverhybrids roverhybrids is offline
Default Which yamaha triple clamps for KYB swap
I've been following the KYB fork conversions and I'm joining band.
I bought some 2009 Yamaha KYB forks.
Now I need some triple clamps and unsure which year and/or offset is best.
I think I read 22mm offset is stock GasGas?
Searching looks like yamaha only had that offset in 2010(and newer?)?
looks like stock yamaha offset was 25mm for 2004-2009.
2011 GasGas ec300R
2011 GasGas ec200 Six Days
Old 06-27-2013, 06:31 AM
pierce's Avatar
pierce pierce is offline
i just had my gasgas clamps bored out that way i didnt have to make new steering stops and mix match bearings and stem. its the simplest way others my say different
Old 06-27-2013, 07:53 AM
GMP's Avatar
GMP GMP is offline
The reason for using the YZ clamps is that the total offset (fork foot and clamps) equals that of the OEM GG and provides excellent steering manners.
Old 06-27-2013, 08:12 AM
Looking at the RG3 website they list the 25mm offset for Yamahas most years.
They suggest 22mm offset for most years......
2011 GasGas ec300R
Old 06-27-2013, 08:50 AM
nknudsen's Avatar
nknudsen nknudsen is offline
Mine are 08' forks and clamps. The fork tube centerline to axle centerline is different GG to Yamaha. It would be interesting to ride a converted bike with Yamaha clamps and switch to one with modded GG clamps and see if a normal person could note the change?
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 06-27-2013, 09:05 AM
Anders's Avatar
Anders Anders is offline
How much does it differ?
I didn't measure mine yet ('08 Yamaha forks and '10 Yamaha clamps).
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 06-27-2013, 09:23 AM
nknudsen's Avatar
Here's some info on the GG to Yamaha differences.
http://www.gasgasrider.org/forum/sho...t=12745&page=3
Noah
15' TW200
Old 06-27-2013, 11:41 AM
Have you tried to fit the gasgas wheel?
What doesn't fit?
How did the yamaha wheel fit with the gg triples?
2011 GasGas ec300R
Old 06-27-2013, 12:27 PM
davedunaway's Avatar
davedunaway davedunaway is offline
Default Kyb conversion
On my swap I used 09 forks and triple clamps (yzf).I used the yz axle and machined up inner sleeves and pressed them into the GG spacers. I had to turn down the one side in order for the wheel to be centered.the biggest hassle was swapping over my sub mounted Scott's damper. The bolts didn't line up and had to buy a BRP mount.It arrived missing hardware and not fitting the yz clamps. Had to do a little boring and scrounge some bolts to fit. Not a big deal but a hassle when everything has to cross the border thru the post. I emailed their customer service dept twice but no reply. Oh well. As for the brakes I used the GG disc and calliper. I had to weld up one hole on the calliper bracket and retap it ,seems to work good. A bit of work but definitely worth it.
Dave
P.S. would love to post pics but I still can't get it figured on my I pad. I've gotten the pics from photobucket to the website but can't manage to get them onto a thread. Give me a tig welder or a lathe any day.
Old 06-27-2013, 12:37 PM
nknudsen's Avatar
If there's a deal someday for the 22mm offset newer Yamaha clamps maybe I'll give it a try?
Noah
15' TW200
triple clamps gassergrant Enduro Chassis & Body 2 10-02-2012 04:23 AM
triple clamps hallyfromspen Enduro Chassis & Body 6 02-25-2012 09:25 AM
Torque value for Triple Clamps? binsel Enduro Suspension 7 03-21-2011 08:42 AM
Can I swap Triple clamps and front forks? FFRDave Enduro Chassis & Body 2 05-24-2010 02:32 PM
Bitchin' triple clamps available?! robinator Enduro Suspension 0 05-08-2009 09:43 PM
