Old 10-02-2007, 07:13 PM
sanderjavant's Avatar
sanderjavant sanderjavant is offline
Default Oil drain plug and radiator cap options
Are their any oil drain plug and or radiator cap options from the aftermarket or other makes?
I have a Moose plug that has the same threads but it’s a little long and I was afraid to try it
Moose Magnetic Drain Plug
Old 10-03-2007, 02:22 PM
Nick's Avatar
Nick Nick is offline
Radiator cap from KTM, why a different drain plug ?
Old 10-03-2007, 07:26 PM
Soft and the hex is wobbled out.
Old 10-03-2007, 08:21 PM
rider01 rider01 is offline
I had the same problem with mine, stripped out. I used the one out of an old KTM motor I have, I had to cut the flange down in a lathe, it wouldn't fit inside the countersunk spot on the crankcase. It also seemed too long but I tried it anyway, it worked just fine. I'll probably order one from gofasters anyhow, as this one doesn't have a magnet in it.
Old 10-04-2007, 04:44 PM
Nick's Avatar
I've never had a problem with one and i change my oil after every ride.
Old 10-04-2007, 05:24 PM
I bought mine used and the more I work on it the more I discover it had a hard life.
Old 10-04-2007, 08:18 PM
Ditto !! I'm in the same boat as you.
PV left drain plug gasgasquebec Enduro Engine - 2 stroke 8 03-20-2010 06:09 PM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil Drain Plug size Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-22-2008 12:08 PM
Oil Drain Plug MIKEWA Enduro Engine - 2 stroke 4 01-27-2007 06:19 AM
