Old 12-30-2013, 09:25 AM
solstice solstice is offline
Default Oops, overheated ec300, what's the damage?
Was out yesterday and holed a radiator, didn't notice until a little later, no water in the rad and very little compression, bike wouldn't restart so got towed home. Looks like the barrel has gone a bronze colour (don't remember it being this colour before!).
What's the likely damage??
Thanks
Old 12-30-2013, 10:56 AM
twowheels's Avatar
Likely need to replate the cylinder, check the head for flatness, piston, rings, and too end bearing ... maybe
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
Old 12-30-2013, 11:47 AM
Zman's Avatar
Zman Zman is offline
Other than the color how does the cylinder look? Are there any scratches or missing plating? How do the piston and rings look?
Old 12-30-2013, 12:03 PM
Just had the head off, the bore looks ok, the exhaust was full of water, drained the gearbox oil which didn't look to have water in it.
Does that sound like a warped head, passing water from the jacket into the cylinder and out of the exhaust port?
Old 12-30-2013, 12:05 PM
Fred1956's Avatar
Fred1956 Fred1956 is offline
Did it get hot enough to melt the cylinder head o-rings? That could be where the water in the exhaust came from
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 12-30-2013, 12:40 PM
Er, what o rings!! I think that might be the problem. Thanks
Old 12-30-2013, 03:06 PM
Zman's Avatar
Yep that will do it!
Old 12-30-2013, 11:59 PM
twowheels's Avatar
Heh! It's often the simplest things Sounds like you might have gotten lucky though.
Steven Beane #275
afterhourscycle.com
Old 12-31-2013, 12:03 PM
Gents, another question, I'm trying to pull the barrel off and need to remove the pin / nut that attaches the power valve actuator plate to the actuating rod. Is it right that this just pushes into the loop at the top of the rod? I was expecting it to be threaded into place, also how does the pin come off ( I' m assuming I remove the nyloc nut and it slides out from the other side of the rod, but it's a bit dark in the shed to say for sure!)
Old 12-31-2013, 01:16 PM
twowheels's Avatar
You can decipher alot by looking at the parts diagrams posted at gasgasmotos.es/manuals or back up a step on this page to exit the forum and have a look.
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
45mm Zokes - Upper fork leg damage smallpuffydog Enduro Suspension 1 04-04-2013 03:20 PM
oops .... skid jackson Enduro Chassis & Body 2 11-11-2011 12:50 PM
Oops !!! I didnt mark the grease ring on the clutch basket FFRDave Enduro Engine - 2 stroke 2 03-14-2009 02:34 AM
Boot damage jhendr3702 General Discussions & Announcements 3 11-08-2008 08:35 AM
Overheated engine Eric K Enduro Engine - 2 stroke 17 11-07-2008 09:01 AM
