Old 04-05-2014, 12:53 PM
spooly's Avatar
spooly spooly is offline
Default kill switch???
the kill switch on the 300 never work since I got the bike its the run type switch ud see on a road bike on and off.but the bike ran fine with the switch in on and off position..so I bought a new kill button the mx type.. so I went about fitting the new one..first I cut the two wires going to the old switch and crossed/joined them to see if it would kill the engine and it did not ..so I traced the two wires back to the ecu and there is another joint just before the ecu so I crossed and uncrossed um there and it still didn't kill the engine..so what do I do now?? I tried put the new swicht straight onto one of the wires going into the coil but the engine will only run with the button pressed so id need a normally closed switch for that method..so do I go and buy a on/off type switch and wire it to the coil. .. any suggestions????
Old 04-05-2014, 01:10 PM
thejackrabbit thejackrabbit is offline
The switch was you map switch, it should be left as a on/off switch. seems as though your kill switch was completely missing
Jack - western PA
2006 KTM 250 sx
2006 EC 200/ 11' style kit--GONE
2004 200 EXC
1997 KDX 220
2004 CRF 250X
1974 CL125
www.youtube.com/allthatstuff35 <---some gasgas videos here
Old 04-06-2014, 09:44 AM
spooly's Avatar
so im getting no where with this switch so I need more help...this is what I have..uploadfromtaptalk1396794909009.jpgold switchuploadfromtaptalk1396794942762.jpgnew swichtuploadfromtaptalk1396794985826.jpgtwo wires going to the old switchuploadfromtaptalk1396795052881.jpgsame two wires going to the cdi, joint in two wires
Old 04-06-2014, 09:46 AM
Coop's Avatar
Coop Coop is offline
That old switch is not a kill switch. That is your map switch (ignition curves). The black and green wires are the two you want for the kill switch.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 04-06-2014, 09:47 AM
spooly's Avatar
uploadfromtaptalk1396795245604.jpg I also found this yellow wire doing nothing just taped up with insolation tape
uploadfromtaptalk1396795387539.jpgcoil
Old 04-06-2014, 10:10 AM
spooly's Avatar
the black and green were the wires going to the old switch I just cut um off the old switch then I joined um as a test to see if it would cut the engine with no success then I tried putting the black and green onto the new swicht notting happened that time either with button pressed/not pressed
Old 04-06-2014, 10:17 AM
spooly's Avatar
so I need to get another on/off (map) type switch and the kill switch wont do unless I wire it straight to the coil..then why is the bike running without the map switch and still running when I cross the two wires going to the map switch even tried touching um off the frame to earth them..
Sent from my GT-I9300 using Tapatalk
Old 04-06-2014, 11:27 AM
Coop's Avatar
What year is your bike? Let me look up the wiring diagram later this afternoon so I am sure I am not offering bad advice...
-Mike
Old 04-06-2014, 12:36 PM
spooly's Avatar
o7 ec 300
Old 04-06-2014, 01:38 PM
spooly's Avatar
https://db.tt/XtuuHWQf an idea of what im working with
Kill switch issues - better one to use? liv2day Enduro Electrical & Wiring 11 01-10-2014 01:47 PM
Kill switch wheelie Enduro Electrical & Wiring 2 05-21-2012 07:12 PM
kill switch Rabbitist Enduro Electrical & Wiring 3 05-22-2011 07:07 PM
Kill Switch Dingo Enduro Electrical & Wiring 4 12-10-2008 04:23 PM
06 Txt250pro - Kill Switch? monkey8414 Enduro Electrical & Wiring 0 01-15-2007 04:16 PM
