Old 05-03-2014, 02:10 AM
gasser's Avatar
gasser gasser is offline
Default Speed limiter for elec. kids bike
Found a cheap source for 12v electric kids bike but need someway to limit the top speed to 2-3mph. Any suggestions?
Old 05-03-2014, 08:55 AM
pscook's Avatar
pscook pscook is offline
Maybe a resistor or potentiometer of some sort? I would assume that the "throttle" directs "X" amounts of volts to the motor controller, maybe measure amount of volts required to go 3 MPH, and get a resistor that matches that amount?
Can you share this source with some of the specs of the controller unit?
Phil
(New bike pending...)
Old 05-03-2014, 02:25 PM
gasser's Avatar
I'll see if I can get more info on the controller.
Old 05-03-2014, 03:29 PM
Zman's Avatar
Zman Zman is offline
Put in a 6v battery.
Old 05-03-2014, 09:45 PM
Zman's Avatar
Another option maybe to put a 12 head light bulb in series with the motor lead.
Old 05-03-2014, 10:03 PM
pscook's Avatar
Or at least a light socket with a bunch of different bulbs to swap in. "It's great traction today, better install the 35w bulb." "It's raining out, probably want the 55w for better traction in the clay."
Seriously, a light bulb would do the trick; however, it would drain the battery faster as it is a constant load on the battery. You would need something that limits the power to the throttle or between the throttle and the motor controller.
Phil
Old 05-04-2014, 08:12 AM
Zman's Avatar
I like the socket idea, but wiring the bulb in series with the battery and motor, will add the resistance of the bulb to the circuit and it will reduce overall current flow. It will split the available battery power between the light and motor. The drop in current flow will make the battery last longer.
If you wire the bulb in parallel with the motor you will reduce the battery life and it will have much less of the desired effect to reduce motor power(unless you choose a high power bulb that draws so much power from the battery that it drops the voltage but that will drastically reduce battery life.
Old 05-04-2014, 09:04 AM
pscook's Avatar
Let me see if I understand this-
Series: Wire the bulb so that it is between the battery and motor (and after the controller), thereby interrupting the juice to the motor with the bulb, diminishing available power to the motor, which makes both voltage draws compete for power;
-or-
Parallel: Wire the bulb in a parallel circuit with the motor (so that it is constantly lit regardless of throttle position and throttle to motor circuit is uninterrupted) and thereby just draining the battery and not affecting the overall operation of the motor draw.
Seems like you could wire in a socket on the Series scenario and add or remove wattage through bulb draw, as a higher wattage bulb would draw more power per throttle setting, all things being equal and constant (not an engineer!).
Phil
Old 05-04-2014, 05:23 PM
Zman's Avatar
That is pretty close, except the higher wattage bulb would actually put more power to the motor because it is less resistance and it would allow more current to flow through the over all circuit.
Mototec electric kids mx bike nknudsen All Other Bikes... 9 05-03-2014 03:47 PM
elec diagrams, do they exist? splint General Discussions & Announcements 1 03-19-2012 09:48 AM
450 Rev Limiter..what rpm? Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 0 05-23-2008 08:32 AM
Bike Dies @ Speed. Ignition???? matt4wheels Enduro Electrical & Wiring 2 04-24-2007 11:35 AM
