Old 05-26-2014, 09:02 AM
boardrider247 boardrider247 is offline
Default Updating hyd clutch AJP to Magura???
I'd like to swap out the AJP clutch master on my 99 EC300 for a Magura master.
They both have what appears to be the same size banjo connection on the slave cylinder. But the AJP uses DOT3 brake fluid and the Mag uses mineral oil. Can I run the AJP slave with the Mag master if I flush all the brake fluid out and fill with mineral oil???
I already have the Mag master on hand and the AJP master has seen better days so this would be a $0 project for me if I don't need to buy a new slave.
Thanks!!!
Old 05-26-2014, 01:46 PM
cbutler's Avatar
cbutler cbutler is offline
The mineral oil will eat the seals in the slave cylinder. You will no longer have the butter smooth pull of the AJP
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-26-2014, 05:29 PM
gasgasman's Avatar
You can rebuild the slave cylinder with mineral oil compatible seals.
Old 05-26-2014, 08:13 PM
Osnabrock Osnabrock is offline
The AJP is nice. I have thought about swapping the Magura on my 2013 with the AJP from my 2003.
Old 05-26-2014, 08:22 PM
cbutler's Avatar
I have ridden bikes with Maguras and was NOT impressed at all
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-27-2014, 11:19 AM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
if the bore sizes are different between the two, the clutch feel/action will also change.
the larger bore means it becomes more 'on/off switch like' so it effects the feel and progressiveness, and the pull gets harder.
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 05-29-2014, 08:40 PM
DWreck DWreck is offline
I know this doesn't do you any good Boardrider but I switched from an AJP to a Brembo that came off a KTM 250/300 and it was an easy swap. They both use brake fluid.
I used both the line and the master. Bolted right up.
I switched because I could never get the AJP to fully disengage. I bled it, rebuilt it and after fooling with it for a couple years gave up on it. The Brembo worked like a champ after a simple bleed.
Old 05-29-2014, 09:39 PM
andoman's Avatar
andoman andoman is offline
Having had lots of KTM's over the years, I concur with DWreck: Brembo is a better option than Magura.
Obviously, any other swap other than to the Magura unit the OP has on hand would defeat the 0$ aspect of the swap.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 05-30-2014, 06:34 AM
WAZ WAZ is offline
Do you know the bore size of the Brembo you used? My AJP isn't great and I'm looking to replace it.
Magura clutch master (question) Mick Enduro Chassis & Body 11 12-21-2013 05:35 PM
Magura clutch MC size on 2012 XC300? Bandit9 Enduro Chassis & Body 2 11-05-2013 07:01 AM
2012 magura clutch lever Diggs345 Enduro Chassis & Body 11 06-27-2013 01:30 PM
WTB: Magura Clutch Master Cylinder + Line egesledder "Wanted to Buy" & "Want To Trade" 0 06-07-2013 02:16 PM
Magura clutch master cylinder on a GG??? ktmguy23 Enduro Engine - 2 stroke 12 04-20-2009 12:44 PM
