Old 06-28-2014, 08:42 PM
Why Z? Why Z? is offline
Default Gunshot sound while starting
Hi,
I disconnected the blue/yellow wire as I was asking in a earlier post and left the black wire.
My main concern is upon startup, if I start with throttle closed, bike will randomly make a loud "GUNSHOT" noise when I hit the button. If I start with throttle at half-open or more, it roars to life first try.
Additionally, here is what I have noticed after disconnecting the blue/yellow wire :
Blue/yellow Disconnected :
-seems to run moderately better/less hot thru all RPMS .
-bike never backfires on decel.
-Harder starting (with throttle closed)
- (LOUD "gunshot" backfire sounds when trying to start (button)
- needs to start with throttle half open (starts 1st or 2nd time as long as I do that)
Before (With wires connected):
-seemed to run a bit hot/lean
-pipe would glow red at cruising speeds (cool outdoor temp) when throttle opened more
-started not super easily, but would start, w throttle closed. Sometimes had to kick the bike manually a couple times .
Old 06-29-2014, 07:08 PM
Is this something to worry about or not?
Valves?
Is this popping on startup a sign I could be damaging something ?
Paranoid to ride ... :-(
Old 06-29-2014, 07:33 PM
wa_ndro wa_ndro is offline
Valves?
its fine, just a bit of fuel backfiring in the exhaust. Ride it like you stole it!
does that sound ok to you bonkeye Pictures & Videos 11 04-12-2016 09:32 PM
Jetting By Sound JP4 Enduro Intake/Carburetion - 2 stroke 14 11-27-2012 11:30 PM
How does my jetting sound? n_green Enduro Intake/Carburetion - 2 stroke 9 09-18-2012 03:50 AM
sound of the engine 300ec Enduro Engine - 2 stroke 10 02-15-2012 02:14 PM
That sound never gets old! Rick Pictures & Videos 6 05-21-2010 12:48 PM
