Old 07-07-2014, 02:35 PM
TavisB's Avatar
TavisB TavisB is offline
Bronze Level Site Supporter
Default Water pump bearing?
I had the clutch cover off to inspect/clean the powervalve parts and when I was getting ready to put it back together I noticed some wear marks and then some play in the water pump impeller (see youtube links).
https://www.youtube.com/watch?v=gxkdsLm4RIE
The shaft looks OK and I didn't have any leaking or cooling issues.
https://www.youtube.com/watch?v=zQMB1TOxz-U
Does the bearing need to be replaced? If so, should I do the seal too? The whole assembly?
[2003 Gas Gas EC250][http://www.motoadventure.me]
Old 07-07-2014, 04:22 PM
Test the shaft in another bearing to try and narrow it down. Those bearings are cheap as chips so I'd probably replace it if any doubt as its cheap insurance.
2010 EC 300 Water pump shaft snapped & bearing collapsed justsam Enduro Engine - 2 stroke 207 03-16-2017 04:25 PM
Water pump seal?? nick790 Enduro Engine - 2 stroke 12 01-31-2009 02:38 PM
water pump? nhrider Enduro Engine - 2 stroke 17 12-21-2008 12:05 AM
Water pump seal brains Enduro Engine - 2 stroke 2 07-26-2007 10:25 PM
water pump impellers splint General Discussions & Announcements 2 07-24-2007 07:20 PM
