Old 08-26-2014, 09:59 AM
doutsh doutsh is offline
Default EC125 - base line jetting
Hi,
I have a 2013 EC125, and it's carb is all over the place.
I couldn't find here any information regarding this model.
Can someone recommend a base-line jetting so i'll have a starting point?
I'm riding at about sea level, at temperature of around 20-30 degrees Celsius.
Thanks!
Old 09-05-2014, 04:42 AM
no one owns a 125?!
Old 09-05-2014, 07:36 AM
Elvis74 Elvis74 is offline
Pilot jet 50
Main jet 188
Needle n1eg
Air screw 2 turns out
Winter
Pilot jet 55
Main jet 195
Rest remains the same
Plus minus individual settings
4 strokes are only good for power generators
Old 09-07-2014, 04:20 AM
Thanks, I'll try that!
Old 09-07-2014, 07:41 AM
Todd5774's Avatar
Todd5774 Todd5774 is offline
So reading those settings, is it a rule of thumb that the smaller the engine the fatter the jetting?
Only reason I ask is that I went leaner when I converted the 300 to a 250..
02 300ec- 50mm Marzocchi cc forks, 2010 plastic.
Now a 250cc.
Old 09-07-2014, 11:30 AM
Yes that's right, small engines require a rich jetting! But only when using the same carb size.
Old 09-07-2014, 02:46 PM
Anders's Avatar
Anders Anders is offline
A smaller engine does not run fatter, it just needs a bigger jet to obtain the same mixture compared to a bigger engine. I guess this is due to the lower cylinder volume creates a lower gas velocity thru the carb.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 09-07-2014, 02:49 PM
That's right!
Ans I don't meant that the engine must run fatter, I just mean the jetting compared to bigger engines. Less air flow in the carb requires bigger jets to gat the same amount of fuel through.
Old 09-08-2014, 06:51 AM
Zman's Avatar
Zman Zman is offline
If you get tired of jetting the 38mm you can always drop in a kx125 35mm PWK carb and be finished. In my opinion a 38mm is too large for a 125 woods bike. This posting provides more details.
http://www.gasgasrider.org/forum/showthread.php?t=17919
Old 09-08-2014, 12:11 PM
I never had any issues with my PWK38! And since I have build it up to a 144cc I doesn't even think about my carb. I my opinion it works great, but I am more riding on motocross track or fast enduros. In Germany riding in the wood is not legal.
wet base gasket thejackrabbit Enduro Engine - 2 stroke 6 02-09-2014 01:03 PM
pfp whats the base line crofty Enduro Suspension 4 12-31-2012 04:38 PM
Ec125 noobi Enduro Intake/Carburetion - 2 stroke 8 09-18-2009 04:12 AM
'09 Ec125 Nhuskys General Discussions & Announcements 8 11-10-2008 07:07 AM
'05 seat base Loosenut General Discussions & Announcements 0 07-11-2008 12:02 PM
