Old 09-30-2014, 08:56 AM
andykr87 andykr87 is offline
Default 2013 complete front brake system crossover
Im done trying to fix the junk front brakes on my 13. They faded/air in the lines the last time i raced so bad a mile in to the race that i whiskey throttled into a tree and havent rode in a month because of it. Asterisk cells and gaerne boots saved my left leg. Has anybody heard of brembos fitting on the gasgas caliper mounting pins and aligning correctly? I have a AA buddy that has three new rmz's that i plan on trying to swap with to see if it works. You can breath on hos brakes and they shut down. Late model rmz brake systems are resonable on ebay so i may go that route if it works hopefully.
Old 09-30-2014, 11:56 AM
Banned
Are you still running the stock banjo w/ the brake wires? I replaced mine with a standard banjo bolt and the front brake is very strong now. 1 finger pull can send me over the bars now. Same for the rear also.
What have you done so far to fix the oem brakes?
Old 09-30-2014, 12:07 PM
phoenix's Avatar
phoenix phoenix is offline
I'm not sure if 2013s were a black hole, but my 2013 300 brakes suck and my 2014 200 brakes rock. Both have the stock banjo. Go figure.
I did try to put a Brembo setup from my Husky TXC 250 on it and it fit without mods except that the rotor barely grazed the inside of the caliper. I didn't feel like it improved the brakes all that much even though the same setup was awesome on the Husky. Maybe the rotor is part of the problem. I swapped everything back and just worked on using a little less front brake and more back.
Richard Wilson at House of Horsepower in OKC swears he has the cure to the ailing GG brakes. Something about a different rotor (not sure which one) and OEM Yamaha pads. He might could hook you up with some info.
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 09-30-2014, 12:08 PM
rosco's Avatar
rosco rosco is offline
Didn't know there was a problem with the stock brakes. I would take nissin brakes over bimbo's anyday.
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 09-30-2014, 05:00 PM
Wimpy525 Wimpy525 is offline
What he says I was so happy to have Nissin brakes over the Brembos. I had a 12 and have a 13 and the breaks seam to be the same. I use good break fluid and bleed them on a regular basis.
Old 09-30-2014, 07:11 PM
kpuc11 kpuc11 is offline
I am brand new to gasgas, coming from ktm, and the 2012 gasgas brakes are way better than my 2012 ktm. just my thoughts.
Old 09-30-2014, 07:14 PM
hamilton's Avatar
hamilton hamilton is offline
I agree the nissin brakes are more progressive and less prone to heat fade then the brembo. You just need to find the cause of your problem.
15 GASGAS EC 250
19 Sherco SE 125R
Old 09-30-2014, 10:13 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
I drilled the stock banjo at 90 degrees t current hole, bleed brakes in traditional fashion, but made sure I kept the line below the mc and percusion tapped line with a spanner as it was bleed, used a super dot 4 fluid and then zip tied the lever in the compressed position for a couple of days. It is now 1 finger and I need to change out the crappy lower spec after market pads I was using as they got hot and grabby. Still progressive but one finger pull. All techniques were garnered through this forum, thanks!
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 09-30-2014, 10:19 PM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
I'm curious about the banjo mod, but I can say the brakes on my gasser are a dream come true compared to the KTM brembos I've owned.
The brembos on my husky were good though, so who knows.
Old 10-01-2014, 06:35 AM
I changed out banjo's, swapped master cylinders, bled, rebled, bled again and nothing. Ive just had it with that set up. Its time for me to swap. I dont have anymore patients. This is the first bike ive owned that i couldnt do a nose wheelie on. I may give that guy a call if another system doesnt feel right
complete front wheel robicon "Wanted to Buy" & "Want To Trade" 2 11-10-2013 08:38 PM
Front Brake Hose Crossover noobi Enduro Chassis & Body 6 12-31-2012 12:48 PM
Front brake Assy crossover gtsnowcrack Enduro Chassis & Body 1 07-24-2012 09:32 AM
Ec250 Rear Brake System gasgasquebec General Discussions & Announcements 8 07-12-2011 09:19 AM
front brake crossover kai69 Enduro Other... 5 09-04-2010 04:47 PM
