Old 11-06-2014, 05:47 AM
dimtsam dimtsam is offline
Default Sachs fork manual
Hi
I got a EC 250 2011. I want to repair my front fork (fork oil, fork seals etc). Wheer can I find a manual of the Sachs fork, so I could find all the infos?
Old 11-06-2014, 06:40 AM
Hahah! Good luck.
What would you like to know? Are they the Sachs with the adjustable preload or no?
Be CAREFUL with the rebound adjuster. Many have cross threaded them on reassembly, and replacements are non existant.
48mm KYB bushings and seals work a treat as far as consumables go.
Air gap 110-130mm.
Basic OC fork - just watch the rebound adjuster. My advice is to push it out of the cap once the cap is off the damping rod. On reassembly thread the adjuster into the damping rod. Then put the cap over the top and thread that down.
Old 11-06-2014, 07:16 AM
the second half of this video will be helpful
https://www.youtube.com/watch?v=N0hj...ature=youtu.be
2003 txt250 Pro
2013 Ossa 280i
Old 11-06-2014, 07:28 AM
Without preload.
Fork oil suggestions?
Old 11-06-2014, 11:30 AM
7.5w according to twowheels on the forum
2003 txt250 Pro
2013 Ossa 280i
Old 11-06-2014, 02:24 PM
Work off viscosity.. Something in the range of say 20-24cSt@40 will do the job. Realistically the fluid is just another tuning variable, so pick one that works and stick with it.
Old 02-11-2015, 06:23 AM
An other question after a long time...The air gap is measured without the spring?
Old 02-11-2015, 09:09 AM
twowheels's Avatar
Yes, spring out, fork fully collapsed. Make sure you have cycled the damper rod and filled the gap between the inner and outer legs.
Steven Beane #275
afterhourscycle.com
Service manual for Sachs rear shock MattR Enduro Suspension 9 10-19-2016 03:18 PM
Replacing 45mm Marzocchi seals, fork service manual? Jkosmo Enduro Suspension 10 09-06-2012 12:13 PM
fork seal change sachs fork Madhead Enduro Suspension 13 01-13-2012 07:49 PM
sachs fork moto9 General Discussions & Announcements 0 09-28-2009 07:51 PM
Sachs Rear Shock Manual MattR General Discussions & Announcements 1 05-05-2009 09:15 PM
