Old 12-10-2007, 07:13 AM
Gas Huffer's Avatar
Gas Huffer Gas Huffer is offline
Default Clutch Drag?
It seems my 03 200ec is having some clutch drag issues. I've been running Shell Rotella 15-40w non synthetic. I ride in Florida it gets very hot and we have very tight sandy trails. I'll work the clutch hard in the tight 1st & 2nd gear trails. I've heard of bleeding out air bubbles in the the clutch line? Has anybody had this happen to them? Or maybe it's time to replace clutch plates. I've done all the adjusting on the lever. When i engage the clutch and put it in gear and try to push the bike it acts like there is not clutch at all. I have since went back to using basic SAE 10w30 oil and still have dragging issues. Any ideas?
Thanks
GH
2003 EC 200
Old 12-10-2007, 08:18 AM
GMP's Avatar
GMP GMP is offline
Bleed the clutch system be sure you have some freeplay at the lever to allow the master cyl. to fully extend. Try the 5W-40W Rotella synthetic, it will work fine. It works in 4-strokes and there is no way your clutch will get as hot as a dry sump 4-stroke clutch even in Fla.
Old 12-10-2007, 01:10 PM
kim kim is offline
Too much oil in the gearbox can lead to clutch drag.
The manual says 1L oil. I have been using 0.9L with good results.
K
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 12-11-2007, 01:40 AM
Bearman's Avatar
Bearman Bearman is offline
I've also noticed that the manual says 1 litre. But the website (www.gasgas.es) says 0.9L. I run 0.9L and it works great, doesn't drag at all.
Ben
'03 GasGas EC200 My bike
'89 Yamaha TT250 R.I.P - Lost in the Black Saturday Fires
Old 12-11-2007, 03:20 AM
iancp5's Avatar
iancp5 iancp5 is offline
I just pour it in until I see it in the little window
It drags just a tiny bit but I use nice light oil. Putoline Light Gear Oil - specially for 2 stroke gearboxes.
Old 12-11-2007, 05:02 AM
Gas Huffer's Avatar
Default Thanks for the info.
Hey Guys-
Thanks for the info on the clutch dragging. I'll try bleeding the clutch line and then using a few ml's less oil. I'll give it a try this weekend.
Thanks
GH
2003 EC 200
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Does your clutch drag? stay_upright Enduro Engine - 2 stroke 11 06-05-2008 03:14 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
