Old 01-22-2015, 05:05 AM
n_green n_green is offline
Default Gas Gas light switch block replacement.
Fine print first: This worked on a 2014 EC300R. Australian spec with e-start.
Background is while the Gas Gas light switch block looks trick and packs a lot of different features into a small ish package there are a few problems with it. The first minor one is it has to be perfectly placed otherwise the clutch lever binds on it, the second is that it sticks out a bit too much so that when you flip/drop your bike onto rocks it tends to smash into itty bitty pieces:
This was my third switch on this bike and at over A$150 a pop I was a bit sick of paying
So I purchased a cheap light switch block of Ebay similar to this one.
Shop around they can be had for as little as $20 delivered.
First thing to do is to cut the wiring loom of the generic switch block to length and work out what each wire is. The switch block should come with instructions telling you which wire is which, if not get out that multi-meter and work it out, then cut the last 4 inches of wiring loom (plug end) off the factory light switch block:
Red - Main 12v power to switch block.
Yellow with green stripe - Main earth to switch block.
White with black stripe - Switched side of E-start switch.
Blue with red stripe - E-start switch. (splices into red wire)
Grey - Switched side of horn.
Yellow with white stripe - Switched side of Kill switch.
Yellow with red stripe - Kill switch. (splices into main earth wire)
Yellow - Power supply to headlight.
Blue - Headlight low beam
White - Headlight high beam
Dark Green - Left indicator
Brown - Right indicator
Strip the wires of the std plug loom and the generic light switch block harness and get ready to solder. If you are doing what I did and wiring in a separate e-start/kill switch strip strip the ends of that too.
The red wire supplies 12v power to the unswitched side (i.e. the switch isn't turned on) for the indicators, horn and e-start.
The yellow with green stripe wire supplies earth to the un-switched side for the kill switch and to the led indicator lights within the switch block.
After twisting the wires together and testing every switch function without blowing a fuse solder the wires together and cover the wiring harness with the insulation tubing/electrical tape whatever. Plug the loom back into the main harness, attach the new switch block to the bars and enjoy.
If you use a KTM e-start switch you the following wires apply:
Black wire - cut it off, this is meant to be earthed to act as an ignition on/off, but Gassers have a key which already does this.
Dark Blue wires - constant earth, spliced into the main earth wire of the switch block loom.
Orange - 12v power. Splices into the red wire of the switch block loom.
White with black stripe - switched earth, splices into yellow with white stripe wire of the switch block loom.
Also, thanks for the tip Simmo, to prevent the kill switch button being a locking on/off switch, you can pull the switch apart and remove the small white locking tab, turning the switch into a momentary on switch, so will only kill the engine whilst the switch is being pushed in.
Enjoy.
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 01-22-2015, 10:59 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Awesome!
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 01-23-2015, 12:00 PM
Neil E. Neil E. is offline
Nice work. There seems to be a few variants of that same light switch. I used the one from here: http://sicassracing.com/store/switch...3c5b375f6e36a4
It has a row of tiny LEDs across the top that can be hooked up as indicator lamps. I used the blue as high beam and the red for power on.
2011 EC250E
Old 01-30-2015, 03:53 PM
Bobt250's Avatar
Bobt250 Bobt250 is offline
Thank you for that info. Mine is also broken and I wanted to do exactly what you have outlined here. My bike is a 2011 but the switch looks identical so I'm pretty sure your info should be of some help to me.
2011 EC300
Old 06-03-2015, 08:16 AM
CombatYoga's Avatar
CombatYoga CombatYoga is offline
n_green is the man!
I booted the stupid bulbous switch since I don't run any lights or use a horn. I installed a Fly Racing aluminum pushbutton switch for the starter and a simple kill switch as well.
Your wire descriptions were right on and made this dead bang simple.
My e-start switch had essentially quit working - now she lights right up.
Slade
'14 GG XC300R - County Cycle Woods Weapon #63
Old 06-04-2015, 04:21 AM
gg3's Avatar
gg3 gg3 is offline
Just what I need!Thanks guys.
Trick gasser switch binds with the clutch lever(thought I had a clutch issue!),breaks first time you drop it(done that) & the kill button is in a bitch of a place for emergency engine shut off, like river crossing.
Old 01-28-2018, 01:59 PM
Dusty1 Dusty1 is offline
Hi mate i have 2011 ec 250 i have same issue i brought a new universal switch but im unsure where to red power wire goes as this new switch doesnt say on the wire diagram
Light and signal switch Waller600 Enduro Electrical & Wiring 5 12-27-2014 06:59 PM
2006 (????) EC 250 Light-switch sevenfourate Enduro Electrical & Wiring 11 12-07-2013 10:50 AM
WTB: Light Switch Coop "Wanted to Buy" & "Want To Trade" 3 05-31-2013 07:18 PM
light ans switch vgstef Canada 1 02-24-2011 07:31 PM
Light Switch question Jeffro820 General Discussions & Announcements 4 10-31-2009 11:53 PM
