Old 03-28-2015, 06:04 PM
Waller600 Waller600 is offline
Default Won't start from cold
Hi
My GasGas EC 300 2006 won't kick over when cold, but once it is running worm(after a tow bump start) it'll kick over first or second kick and is running better than before
I have recently had the carb out to clean it and to put a new 38 jet in and also replace the over flow pipes, but it hasn't started nicely since
It's running N1EG. 168. 38.
Any ideas? Thank you
Old 03-28-2015, 07:00 PM
Rod Overstreet Rod Overstreet is offline
Originally Posted by Waller600 View Post
Hi
Low on compression? Have you tested?
Old 03-28-2015, 08:11 PM
Mine does the same thing and it has 15 hours on it. It is more than likely a jetting issue or low compression. Mine didn't start doing it until I started playing with the jetting
Sent from my iPad using Tapatalk
Old 03-28-2015, 10:02 PM
shultzy shultzy is offline
38 is a pretty lean pilot. My 2011 300 Race was always a little hard to start cold since new. Once I put in in a 42 it was improved and a 45 was even better ( Nedj 2nd clip 45, 172). Always ran and started great once warm.
Other things to check would include leaky crank seals, worn reeds, float level, and as others stated compression. Poor wire connections can also cause difficulties. Plugged carb passages can also happen. Lots of things can contribute to starting difficulties, but I would try a richer pilot to start with.
Old 03-29-2015, 05:56 AM
Thanks all
Compression on the kick is good, but I did have a 40 jet but it did seam to run rich, and had a wet stark plug , so put a 38 in it, but think I better try putting the 40 back in again see if that helps
Old 03-29-2015, 11:50 AM
Well we put the 40 jet back in and we did get it started! So gonna try from cold a couple more times and if it starts ok I'm gonna leave it the hell alone! Lol
Thank you for your help and input guys x
Old 03-30-2015, 08:47 AM
bukwheat's Avatar
bukwheat bukwheat is offline
Try this when cold...
Put bike in 2nd or 3rd gear, without the clutch, try rolling the bike back and forth vigoriously for maybe 30 seconds. The compression of the engine will pull a bit of fuel into the cylinder....
Have the choke on, no throttle and kick....
Old trick...some people lean a bike over until gas runs out the overflow....try the above. Works everytime...for me.
Alan
14GasGas ec300r
Old 03-30-2015, 08:57 AM
Worth a try cheers
Old 03-30-2015, 12:11 PM
Well after putting the old jet back in yesterday today tried this ^. And it started second kick !
So not sure if it would have anyway but happy with the outcome
Old 03-30-2015, 04:59 PM
Good habit to get into I find. Also helps free up the clutch plates if they have stuck a little while sitting.
I usually turn the engine over a few times before giving it the boot as well.
EC515FSR hard to start when cold Toontje Enduro Engine 4 stroke (including EFI & Exhaust) 12 07-01-2014 03:17 AM
Bike is hard to start when cold? blanc General Discussions & Announcements 2 07-02-2011 03:07 PM
Hard cold start rupecopp Enduro Engine - 2 stroke 8 11-30-2008 10:54 AM
Need help with cold start brains Enduro Intake/Carburetion - 2 stroke 12 01-11-2008 05:47 PM
'05 FSE won't start when its cold. AAARRRGGG! cobrad Enduro Engine 4 stroke (including EFI & Exhaust) 6 05-13-2007 08:37 AM
