Old 05-29-2015, 02:01 PM
gump147's Avatar
gump147 gump147 is offline
Default More ec 200 problems
Well I thought it was fixed but guess not it will start up and run for about 5 min then it quits like it runs out of fuel but it quits getting spark I let it set for a few minutes (less than 5) and it gets spark again and will run for 5 more minutes or less where to start stator coil cdi ecu or just wires I'm lost when it comes to this kind of problem thanks for any help
Old 05-29-2015, 02:34 PM
Thomas R Thomas R is offline
Breater in the gas cap is blocked. Mine did the same
Old 05-29-2015, 02:37 PM
Sorry did not se the misding spark thing, could i be the ignition coil, when broken they usualy fail when getting hot.
Old 05-29-2015, 03:06 PM
gump147's Avatar
The ignition coil is what the spark plug wire comes from right I no its probe a stupid question but I've looked at so many things I think I've confused myself thanks
Old 05-29-2015, 03:10 PM
gump147's Avatar
Default ec200 problems
Also another dumb question are the ignition coils bike specific can I try on off of one of my other bikes they look the same
Old 05-29-2015, 03:12 PM
It is :-) if you got some freeze in a can you can give it a spray, compresed air i a can turned up side down should do the trick as well. Stupid fault to find.
Old 05-31-2015, 10:06 AM
thejackrabbit thejackrabbit is offline
check the kill switch, I had to solder it back together on the bars at one point, maybe its acting up, it never did for me though
Jack - western PA
2006 KTM 250 sx
2006 EC 200/ 11' style kit--GONE
2004 200 EXC
1997 KDX 220
2004 CRF 250X
1974 CL125
www.youtube.com/allthatstuff35 <---some gasgas videos here
Old 05-31-2015, 06:31 PM
gump147's Avatar
Default ec200
Thanks ill check there as well I'm in the process of checking resistance on everything and tracing all wires ill keep everyone informed
Old 05-31-2015, 08:46 PM
also check the yellow wire by the top shock mount on the left side if sitting on the bike, I remember it becoming exposed at one point and I covered it with electrical tape but that may have fallen off now causing a short?
Jack - western PA
2006 KTM 250 sx
2004 200 EXC
1997 KDX 220
2004 CRF 250X
1974 CL125
Old 06-01-2015, 03:15 PM
gump147's Avatar
Default ec200
Ok thanks I'm trying everything never had anything like this happen some are saying its the stator but in my experience when there bad there bad but I could be wrong ill try that wire as well thanks any other advice is welcome
yet more problems bonkeye Enduro Electrical & Wiring 9 08-17-2013 09:48 AM
Shifting Problems jyellard Enduro Engine - 2 stroke 2 05-18-2009 05:05 AM
CDI connection problems. HELP!!! ejas66 Enduro Electrical & Wiring 4 02-18-2009 03:16 AM
03 300 Problems Ryan#87 Enduro Engine - 2 stroke 3 06-15-2008 10:28 AM
06' ec 200 problems speed addic Enduro Engine - 2 stroke 0 02-25-2007 06:44 PM
