Old 07-06-2015, 02:32 PM
Steve-A Steve-A is offline
Default Frame Rust! :(
nknudsen was asking about my frame rust in my parts for sale thread, and so I thought it might be a good idea to start a fresh thread to discuss it, and as a slight warning to others
Filling in the back story, I bought my '01 EC200 a couple of years ago, with the intention to get into green laning. I never really got round to much off road so it's spent much of lit's life with me as a supermoto.
Last week I was working on diagnosing a running issue (turned out to be cracked reed petals) and I noticed this worrying looking hole in the frame where the down tube splits into the two smaller tubes that run under the engine.
I spend a lot of time around classic cars, so I'm well used to rust, and quite a competent welder. So I figured it looked a simple enough repair. I stripped the bike down so I could get a better look at the frame, and after a bit of poking about with a screw driver the rust was clearly a bigger issue than I first thought.
Still, not a difficult area to patch and repair, so the next step is to get in there with a grinder and cut it back till we have clean metal to work with.
Oh? After cutting back the area around the two obvious holes in the previous photo, I could see inside the box section down tube. Inside were 2-3 handfuls of mud and rust flakes. The box section down tube had completed rotted away in some places where the two lower frame tubes join up. In this picture I had got in with a screw driver and poked around a bit to find out what was paper thin and flexible and what wasn't so it looks a bit more exaggerated that it did when I first opened it up.
Lifting the frame up, I could hear mud/rust flakes siding around inside most of it. With that in mind, I have the whole frame a bit more of a prodding with the screw driver and found a couple more small holes in one of the lower frame tubes, underneath where the engine sits. So I decided to cut into it and open it up to look inside.
Again large amounts of mud and rust flakes came out, and it's clearly weakened in there.
At this stage, it's clear to put the strength back in this frame would be a very large job, certainly requiring serious jigging, if not just ending up with the standard headstock and a completely rebuilt rest of the frame! So it's going in the bin.
From the outside the frame really didn't look so bad, it was clearly rusting from the inside out. Now that I've got the frame upside down in the garage and can study it, I can see that most of the frames tubes have got small drain holes in them, all of mine were completely blocked up with mud, so the frame wouldn't have drained properly. From my 4 wheeled experience I know just how much damage that trapped moisture can do.
Hopefully someone can read this, clear out their drain holes and save their frame before it rots out like mine has!
Old 07-06-2015, 03:22 PM
nknudsen's Avatar
nknudsen nknudsen is offline
Thumbs up
Thanks for the heads up! I'm going to look my drain holes over very closely and probably spray some fogging oil inside the frame too.
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 07-06-2015, 06:02 PM
Zman's Avatar
Zman Zman is offline
Holy smokes!!!!!!
Old 07-07-2015, 10:50 AM
jhendr3702's Avatar
jhendr3702 jhendr3702 is offline
wish you were not in uk... I have an 01 frame in my shop.......
broken down over 60 slow rider..
Old 07-07-2015, 10:56 AM
Cheers for the thought jhendr3702 Damn ocean in the way, not to mention the registration issues!
I suspect that the fact that I'm the uk probably has something to do with the rust, we do have our fair share of rain and salted roads in the winter...
Old 07-07-2015, 12:24 PM
jhendr3702's Avatar
yeah... I guess so...
momma wants to take a trip there one day....prolly wont fit in my luggage anyway....lol (that would flip the tsa agent out....
Old 07-07-2015, 12:29 PM
nknudsen's Avatar
aah..... F'n salt, so not normal wet/mud riding conditions.
Noah
15' TW200
Pipe surface rust removal? liv2day Enduro Engine - 2 stroke 11 04-02-2014 11:27 AM
Link to WEC Heinola Finland Frame by Frame REVERUP Pictures & Videos 0 09-16-2012 09:31 PM
2002 frame; same as a 2005 frame, or close enough? Trooper Sam Enduro Chassis & Body 0 06-10-2010 09:18 AM
Would a 450 fit in a 400 frame? douglase1983 Enduro Engine 4 stroke (including EFI & Exhaust) 2 03-16-2009 11:43 AM
Rust on my shock Gonzo Enduro Suspension 3 08-30-2006 01:29 AM
