Old 11-08-2015, 03:23 PM
Victory6541 Victory6541 is offline
Exclamation 450FSR 2008 Valves and ignition
Hey ppl!
I'm having trubble finding the right valve adjustment setup. How to place the exhaust and intake camshafts.
Also another issue were the bike runs smooth while idle. But as soon as you turn the throttle abit it wants to die any idea what it could be?
Regards Jocke a typical sweed
Old 11-15-2015, 01:37 PM
Leeky Leeky is offline
Hi, do you have a copy of the workshop manual? I googled it and found one. Follow the pics and ensure you get the arrows on the cams pointing to the correct pin (left pin on the link for the exhaust cam on my 04 engine from memory and then count the 15 pins back to the inlet arrow) this sets the cam to crank relationship.
If you get this wrong (like I did initially) it will run but is terrible to start and won't pickup properly, it also kept cutting out on idle.
Old 03-11-2016, 01:29 PM
redvan redvan is offline
Hello, i am from spain.
Where can i buy the electrical diagram of fse450 2009?
I looking for it and i havent found it. I am deses?rate....
Thank you!!!
Gas Gas 125 power valves geoffg Enduro Engine - 2 stroke 8 10-28-2010 01:23 PM
after market base valves 45/50mm marzocchi armyoforange Enduro Product Announcements 9 01-23-2010 10:58 PM
reed valves for VF3 perfex Enduro Intake/Carburetion - 2 stroke 16 03-13-2009 11:47 PM
Snapped valves on 02 400 douglase1983 Enduro Engine 4 stroke (including EFI & Exhaust) 3 01-10-2009 01:33 PM
08 450fsr electrics splint General Discussions & Announcements 1 06-04-2008 03:41 AM
