Potential front and rear caliper upgrades?
I'm curious what other bikes use the same calipers as our GasGas bikes. Rebuilding and using sintered pads still doesn't give me the bite I want out of my brakes. Searching for GasGas calipers only offers up OEM.
What year bike? Some came with Nissan some with Brembo.
If you have presser switch banjo bolts that could be your issue.
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
I actually didn't have the brakelight switch bolts until just recently - with the new sintered pads the stopping power is improved, but the feel is still softer than desired. The front master is new so I doubt it needs rebuilt.
It's an 01 so it has Nissin. I've got Marzocchi 48mm forks which came off of a 2013 I believe, but the 01 caliper bolted up fine. Curious though, if there are any 4 piston calipers around that'll mate up the same. The bike is in supermoto form right now so tire grip on the street is quite good and makes locking up the rear quite difficult. |
Front caliper crossover | motopsycho87 | Enduro Chassis & Body | 15 | 01-29-2015 03:25 PM |
Front caliper rebuild kit? | motopsycho87 | Enduro Chassis & Body | 3 | 12-07-2014 12:09 PM |
Nissin front caliper/M.cyl. NEW | john r b | Parts | 0 | 03-21-2014 03:49 PM |
Rebuilding 03 EC125 front caliper. What seals? | fire1998 | Enduro Chassis & Body | 0 | 04-23-2013 08:33 PM |
'06 EC300 Nissin Front caliper | brider | Enduro Chassis & Body | 7 | 12-01-2012 02:09 AM |
