Old 02-06-2016, 08:18 AM
imsimon imsimon is offline
Default replacing the lower shock bush/bearing
Hello.
ive got a 2007 model ec 250 ohlins shock, got new kit for the lower mount, can I do it without removing the linkage? If so any tips on how to make it easier? I guess use a vice with sockets?
Cheers in advance
Old 02-06-2016, 11:47 AM
john r b's Avatar
john r b john r b is offline
Best to remove the shock completely from the bike.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 02-06-2016, 11:56 AM
Yep thats no prob, but ok to still do it with linkage all in?
Old 02-06-2016, 12:27 PM
john r b's Avatar
pretty sure you will need to remove the linkage,while your there why not check the seals and bearings? Grease em up if need be.
'12 XC 200 TTX Sold
Old 02-06-2016, 05:51 PM
gasgasman's Avatar
You can do the bearing with the shock on the bike.
Just remove one of the dog bone bolts and rotate dog bone out of the way.
Old 02-07-2016, 01:14 AM
Is it then just a case of use vice and sockets to press the old out and new in? ill probably pull the shock and send for a service while a few bits are apart
Old 02-07-2016, 01:37 AM
Tricky part with this method is lifting the bike onto your vise to press the bearing out ;-)
2003 txt250 Pro
2013 Ossa 280i
Old 02-07-2016, 05:54 AM
Anyone know what size the o-ring seals are for the lower shock linkage? And are they rubber or button?
2003 txt250 Pro
2013 Ossa 280i
Old 02-07-2016, 07:51 AM
Zman's Avatar
Zman Zman is offline
You can also use threaded rod, washers and sockets to make a puller/press.
Old 02-07-2016, 12:21 PM
Any chance you can explain in stupid persons terms how id make and use this way?
2012 Ohlins lower shock bushing and Problem with shock. CDBiker220 Enduro Suspension 1 08-04-2014 09:35 PM
washers on lower rear shock? lineman12345678 Enduro Suspension 19 06-20-2014 04:35 PM
Stripped lower shock mount andykr87 Enduro Suspension 12 05-08-2013 09:11 PM
lower shock bearing cross-ref? fasternat Enduro Suspension 1 02-21-2007 10:20 AM
