Hard starting
2014 XC300R - HoH pipe/silencer/slide, S3 head, running Torco Accelerator for 98 octane.
I removed all of the estart crap off the bike and am kicking it now. Our harescrambles series is a dead engine start. Esmerelda doesn't always light up on the first kick, which can be an issue for the races. Any thoughts/tips/suggestions on how I can improve that? I am definitely ratcheting the starter up to the top so that I get a full kick. It's not that it never lights on the first kick, but oftentimes it takes 2 or 3 kicks.
Slade '14 GG XC300R - County Cycle Woods Weapon #63 |
put the estart back in?? probably not what you want to hear, but hey it was you asking for suggestions.
Hey Mark - I am starting in 2nd gear.
I have learned to keep the clutch in and rev the bike prior to killing it to make sure those clutch plates release as much as possible. I was wondering if my kickstart troubles had anything to do with the higher compression head? And if so, what some possible solutions were. I've never had the squish properly measured - I assume this is still an issue with the S3 head? Would that help?
I meant Rod - trying to do too many things at once - sorry Rod!
I don't know how my Gasser starts with the kicker, I'm addicted to the button start. If you are in gear when you are kicking it you are going to have some drag. I think that is what Rod was referring to in his post.
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
I am using the middle insert (high compression) - not the ultra-high compression head.
I realize that I will have some drag starting the bike in gear (I run a Core 3.0 Rekluse as well). That's why I mentioned that I take some precautions to try to get the clutch plates to release when I get to the line. The issue for me is that the bike lit up immediately on the first kick (even half kicks) every time prior to the latest round of changes (adding the S3 head, etc.). Now it's a bit of a gamble. Last Saturday I was second to the first turn - the bike lit right up. On Sunday it took three kicks and I was second to last to the first turn. Just wondering if there is anything I should look at to improve that consistent starting. Thank you for letting me know that you love your estart. ;-) I loved mine too until I went through a bendix and 2 ring gears.
Starting
Try priming the cyl by holding on the throttle open a bit while hitting the kill switch. After the bike is off I keep the clutch in and rock the bike back and forth a bit to insure the clutch is free. I run a S3 head with same insert and can usually do very well with my starts. Hope this helps
Extremely hard starting problems | Crankin04 | Enduro Engine 4 stroke (including EFI & Exhaust) | 27 | 01-11-2021 02:12 AM |
Hard Starting '07 FSE | Why Z? | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 06-06-2014 12:35 PM |
300 hard starting warm Having some carb issues. | Ed Ventura | Enduro Intake/Carburetion - 2 stroke | 1 | 03-11-2012 08:12 PM |
04 EC 300 Hard Starting | lordfeyr | Enduro Engine - 2 stroke | 4 | 01-25-2010 01:18 PM |
Hard starting - Timing change? | mattmax | Enduro Engine - 2 stroke | 14 | 03-03-2007 01:03 PM |
