Old 04-03-2016, 10:31 AM
Zman's Avatar
Zman Zman is offline
Default LED Bulb for Stock Headlight
I was putting a headlight on a 2002 GG MC125. I wired up a new regulator/rectifier on the bike and I fired it up and promptly burned out the headlight bulb. I must have gotten a bad rectifier. We were leaving for a trip and I did not have another rectifier so I remembered that the new LED bulb I put in my 300 was rated for 80V AC or DC so I gave it a try. It worked perfectly all trip without a regulator/rectifier.
This bulb even on the low beam setting is much brighter than the stock incandescent bulb on high beam. For $12.5 it is a simple and cheap upgrade.
http://www.ebay.com/itm/1x-DC-6-80V-...UAAOSwKrhVb-2i
Old 04-03-2016, 10:35 AM
Neil E. Neil E. is offline
Interesting bulb. Did you ride a night? What was the beam pattern like?
2011 EC250E
Old 04-03-2016, 11:51 AM
shang shang is offline
Thanks for the info!! I just ordered one. My 06 just burned out a bulb. I'm excited to try the LED!
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 04-03-2016, 06:00 PM
Zman's Avatar
I did ride around the block with it and I thought it had a better spread than stock. With the added brightness it was more usable on the 35W lighting coil.
Old 04-04-2016, 05:27 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
Good info, thanks. I've got a '01 XC200 that needs one of those bulbs.
RB
Old 04-04-2016, 07:28 AM
Zman's Avatar
I was able to get them a little cheaper with a best offer when I bought two bulbs.
Old 05-05-2016, 04:59 PM
rvangeel rvangeel is offline
How did you guys mount this headlight bulb? I bought one but don't see how it will fit.
Old 05-05-2016, 05:05 PM
john r b's Avatar
john r b john r b is offline
Changing the bulb socket looks to be one way.? I was wondering the same before I order.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 05-05-2016, 05:12 PM
phoenix's Avatar
phoenix phoenix is offline
Aren't the more recent bikes using H4?
http://www.ebay.com/itm/2x-H4-120-LE...9XAeyk&vxp=mtr
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 05-05-2016, 07:07 PM
Thanks. That H4 bulbs looks even better. The first one I bought only has one large LED bulb and it is mounted perpendicular to the main body so the light wouldn't be projected very well in the housing of the gas gas bike.
Small bulb in headlight assembly? liv2day Enduro Chassis & Body 10 06-11-2014 05:27 PM
2011 headlight bulb skid jackson Enduro Electrical & Wiring 34 11-08-2013 06:51 AM
LED H4 bulb desertgasser300 Enduro Electrical & Wiring 10 10-04-2013 09:39 AM
Spring to hold in headlight bulb c337b Enduro Electrical & Wiring 1 10-09-2011 02:04 PM
Headlight Bulb Kurdt Enduro Electrical & Wiring 1 09-01-2010 10:23 PM
