Old 04-04-2016, 03:40 PM
Caravan Monster's Avatar
Caravan Monster Caravan Monster is offline
Default 2006 EC200 ignition fault diagnosis
2k3 ignition and the plug sparks when the engine is turned. Strange fault cut the last ride short. I'm 90% sure it's an ignition fault - the bike became increasingly hard to start, then would just about run at low rpm whilst cutting in and out every few seconds.
What little I know about ignition is mostly from youtube Could someone more knowledgeable check my results are in the right ballpark:
Pulse Coil (red-green wires) 97.2 ohms (manual=100 ohms)
Exciter Coil (black/red - red/white) 14.4 ohms (manual=12.7 ohms)
B8EGV (no resistor) spark plug - cap end to tip 0 ohm, cap end to threads 0 ohm (same result when heated)
HT lead and plug cap - visual inspect - insulation in good condition, plug cap to end ht lead= 4.5 k ohms, check continuity whilst flexing ht lead=same result
Coil, centre core to tab= 0 ohm, centre core to ht lead 'screw'= 0 ohm
Under the ignition cover, everything is clean and dry. I pulled the flywheel and stator plate to check, all looking good. The main bearing seal is also clean and dry. Maybe worth checking the carb, reeds and p.v., but would be suprised to find any problems there.
I guess I could double check the continuity of the wires to the cdi (multipin) plug. Other than that, the cdi would need sending away for testing.
Any ideas on anything else to look for?
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 04-04-2016, 04:31 PM
pigpen966 pigpen966 is offline
Look at the coil to spark plug wire connection.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Neil E. Neil E. is offline
You checks seem OK. If you have good spark while kicking, maybe the fuel system should be inspected for problems.
2011 EC250E
Old 04-05-2016, 01:33 AM
Anders's Avatar
Anders Anders is offline
I had a similar problem on my 06 200 a few years ago. Turned out to be a bad ground connection at the ignition coil.
The coil is grounded to the frame via the screws. Remove the coil and make sure you have bare metal where the threaded clip sits on the frame tab. On my frame it was quite rusty.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 04-05-2016, 01:54 AM
VilluEST VilluEST is offline
Did you try with a new spark plug? I had exactly the same problem once: spark was there when inspected out in the air but not under compression in the cylinder. New plug and still runs fine.
Old 04-05-2016, 09:43 AM
Thanks everyone ! Think I have found the problems - as Anders mentioned, the surfaces where the coil grounds to the frame had got rusty and pigpen was also correct about the coil > ht lead because there was water and dirt in there. It starts easily and revs now and I will test it out in the dirt in the next few days.
I guess the lesson was to pay attention to the small details
'13 Husaberg TE 300
Old 04-05-2016, 03:11 PM
Took about a month for me to find it. I was ready to signal the sweep crew with a cloud of black smoke
Dick Carnes
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
Old 04-10-2016, 10:32 AM
Default any electronics experts ?
It went bad again. My bike has a separate ignition loom and the Coil (W/Blue), Ground (Blk/W) and Engine Stop (Blk/Y) are routed along the right hand side of the perimeter frame to the coil. The 'wiggle the wires' test seems to cause the ignition to go wrong. Presumably it is the earth or coil wire that is breaking up. I think that as the fit of the fuel tank has got tighter with age, the tank may have crushed the wires against the frame (although there is no obvious damage to the insulation). The previous owner was also a very enthusiastic user of cable ties, which could also have caused damage.
What I would like to do is replace the 3 wires from the cdi plug (the bike fires up first kick when the wires are wiggled right). The cdi is the multipin connector one ME250834007. Does anyone know the specification for the female crimp terminals used in the multipin plug ? I've spent hours searching the web to no avail.
'13 Husaberg TE 300
Old 04-10-2016, 11:53 AM
Anders's Avatar
Yes I have it somewhere I think. I bought one of those plugs when I was havn my problems. I'll try to look it up later tonight.
Anders
1986 Duc Mille S2
etc
Old 04-10-2016, 05:09 PM
Anders's Avatar
I found the invoice from Digikey.
The housing:
http://www.digikey.com/product-searc...ds=670-2463-ND
The front:
http://www.digikey.com/product-searc...ds=670-2464-ND
Dummy pins:
http://www.digikey.com/product-searc...ds=670-1681-ND
Pins:
http://www.digikey.com/product-searc...=670-1682-1-ND
I hope this is what you were after.
Anders
1986 Duc Mille S2
etc
A lot of fault spark plugs... dimtsam Enduro Intake/Carburetion - 2 stroke 6 11-14-2014 09:51 AM
EC200: Ignition test 2K2 vs 2K3 firffighter Enduro Engine - 2 stroke 2 08-26-2014 11:41 PM
Fuel tap fault Warwick Simpson Enduro Intake/Carburetion - 2 stroke 0 11-09-2008 12:15 AM
EC200 ignition ? mudskipper Enduro Electrical & Wiring 4 09-05-2006 08:38 PM
