Old 05-22-2016, 07:57 AM
doutsh doutsh is offline
Default Catalog number needed - bolt between main and sub frame
Hi,
In my 125 (and I think it's the same at least in all 2 strokers) the subframe is attached to the frame on the bottom side with 2 bolts + nuts + special washers from each side.
I can't seem to find these parts in the microfiche...
I need the nut side, it's a special nut with 10mm head and long spacer attached to it.
Thanks!
Old 05-22-2016, 10:01 AM
cbutler's Avatar
cbutler cbutler is offline
T2108001 is the nut looks to be the same from 01-11
this is the parts fiche from GoFasters just put in the year.
http://partsfinder.onlinemicrofiche....?make=gasgasdb
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-22-2016, 10:23 AM
gasgasman's Avatar
The nut is slimmer than a conventional nut, so it will clear the swingarm.
If you can't find one, maybe grind the conventional nut down.
Old 05-23-2016, 11:06 AM
Thank you for the help, but I don't think it is the same part.
In the 2013 the nut comes with some kind of spacer, something like this:
Old 05-23-2016, 12:26 PM
gasgasman's Avatar
That's a Rivnut. It is not serviced separately. Not to say you can't replace it.
You can buy the Rivnuts and replace them yourself. They do require a special tool for the installation.
Old 05-26-2016, 07:04 AM
I don't think it's a rivnut
I found the part (or similar) at haines, but don't write the catalog number, and they charge 10 pounds before shippment!
This is the part:
no frame number??? leeroybrown9 Enduro Chassis & Body 2 07-23-2013 03:33 PM
main bearing failure right side 2006 ec300, rebuild tips needed. hillbilly Enduro Engine - 2 stroke 11 03-16-2012 04:42 PM
