Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > Other GasGas Bikes/Quads
Other GasGas Bikes/Quads Trials, Pampera, Wild HP, etc.
Old 05-25-2016, 11:38 AM
Blambo Blambo is offline
Default How to drain Pampera coolant
Hi,
Unlike the EC, there's no Service manual on-line for the Pampera 250 2-stroke (mine's a 2002 mk3).
So, please can someone tell me how to drain the coolant ?
The EC has a drain hole on the pump-cover, but the Pampera doesn't.
Do I take the whole water pump cover off ?
This seems logical, but I don't recall doing this before (it's been a loooong while, as the bike wasn't used for years) and I'm nervous about needing a new rubber seal for the cover as Pampera spares are not easy to get these days.
Thanks for any help,
Mike in the UK
Old 05-25-2016, 04:45 PM
Neil E. Neil E. is offline
Instead of disturbing the cover, what about removing the lowest rad hose connection and leaning the bike over to get the coolant out?
2011 EC250E
Old 05-25-2016, 05:33 PM
cbutler's Avatar
cbutler cbutler is offline
The Pampera has a trials motor. I just looked at my 01 TXT 280 and it is a Phillips screw just behind the front bolt on the cover.
Can you post a pic. ?
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-26-2016, 06:14 AM
Those connections are crimped on, one-time use. Best left alone...
Old 05-26-2016, 06:15 AM
The Pampera pump cover has 2 allen key bolts. Nothing else. I guess I just remove it...
Tags
coolant, drain, pampera
oil drain washer kyton Enduro Engine - 2 stroke 12 09-10-2016 02:34 PM
Best Way to Drain Out Gas VTMTcowboy Enduro Engine - 2 stroke 4 05-10-2016 02:05 PM
Coolant drain Buysomerice Enduro Engine - 2 stroke 2 10-06-2014 05:52 PM
First coolant change - $#%+ In coolant?? Why Z? Enduro Chassis & Body 10 06-26-2014 03:32 PM
Coolant drain bolt Lonestar4x4 Enduro Engine - 2 stroke 7 05-24-2012 08:13 AM
